It is currently Thu Jan 01, 2026 4:46 pm
 Post subject: steering column
PostPosted: Fri Sep 25, 2009 1:18 pm
I found in the mist of some old junkyar Dusters a column for a floor shift car Its attached to a power steering box but dont think it matters will all the stuff in it work for my 72 ii might have have to put my elctronics from my other one into it? I got manual steering
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Fri Sep 25, 2009 2:25 pm
The shaft for a power steering car is shorter than for a manual steering car. An adapter is readily available to make it work. I don't know whether it is possible or feasible to swap the shaft from one to the other.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Sep 25, 2009 2:41 pm
from what it looked as of looked about the same i mean?
PostPosted: Fri Sep 25, 2009 2:45 pm
A tape measure will tell the tale. The difference is several inches.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Sep 25, 2009 2:51 pm
well taht is the only one i found out there that had it for a manual in floor so thosse adaprtsre are they easy to fine
PostPosted: Fri Sep 25, 2009 3:30 pm
I know that Flaming River has them and I expect that Firm Feel and Steer and Geer will have them as well. I don't know the cost.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Sep 25, 2009 3:56 pm
guess thats all alone stuff then erm guess go to alot more junkyards and find something else
PostPosted: Sat Sep 26, 2009 6:02 am
The adapter is 125.00 at FirmFeel.
As I said before, it might be possible to swap the steering shaft from the column shift column to the floor shift column. Someone with the appropriate year FSM might be able to tell you more.
Another possibility it to swap the collar at the top of the column.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Sep 26, 2009 7:24 am
I'm going to try the swap---
I have a floor shift car now with p/s.
I purchased a manual steering column with the gear selector-- I will then swap the floor shift parts on to the manual shaft & hopefully I'll have a floor shifted manual steering car. This is on a 69 dart.
Lawrence
PostPosted: Sat Sep 26, 2009 8:40 am
6 Pack Dart
Why not just use the outer housing from one to the other :?:
PostPosted: Sat Sep 26, 2009 9:31 am
I'm not to the point of swapping -- just have the parts to do it-- My friend said it takes less than 30 minutes to swap the parts---- a manual column is cheap if it is the gear selector type. Lawrence
PostPosted: Sat Sep 26, 2009 3:19 pm
The later ones with the column mounted ignition and collapsible column are more complicated but I can't believe it would be all that difficult.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Sep 26, 2009 6:01 pm
its always one of thosse things you wonder why the heck the did it XD
PostPosted: Sat Sep 26, 2009 6:41 pm
They did it because the Federal Government mandated collapsible columns and locking steering wheels.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Sep 26, 2009 7:58 pm
mine locks or used too when itwas sitll in car how many colums will work in a a body just abotu every a body one?
