It is currently Sun Apr 26, 2026 9:26 am
PostPosted: Fri Nov 06, 2009 6:26 am
I've got some loud noises coming from under the cab of my 87 pickup. Sounds like hog luv'n. There is a crossmember that appears to house a transmission mount or bushing. Its hard to see whats there. I noticed a nut protuding from the area is rubbing on one part of the crossmember. My question is is there a bushing/mount there? If so, is it a real bear to repair if its failed somehow. This truck has been bouncing around a farm for 20 years and I'm still having driveline vibrations after a ujoint repair.
________
W125
PostPosted: Fri Nov 06, 2009 7:07 am
Yep
Trans mount. Can be easy or tuff to do, depends on how rusty the hardware is.
It will really help the vibrations too. I have a mount gone in my 87 and it vibrates bad, my 82 is good and smooth.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Nov 06, 2009 8:21 am
As long as that mount isn't as bad as an'83 Mercedes 300td motor mount I may survive the repair. It just hit me--the list of vehicles you have there, Frank. You're living the Mopar high life!
________
Honda XL125
 Post subject: Sound
PostPosted: Fri Nov 06, 2009 8:49 am
Are you sure you want to fix it. You will not hear any more "hog luv'n" :lol:
PostPosted: Sat Nov 07, 2009 5:34 am
I actually have 4 not listed here!!! :oops: :oops: :oops: :oops: :oops: :lol:
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
