It is currently Wed May 13, 2026 6:49 am
Post new topic  Reply to topic  [ 74 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Nov 30, 2009 5:24 am
Looking good Kevin. Keep up the good work.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Nov 30, 2009 6:53 am
username: Kevin Johnson is <unignored>
Cool stuff Kevin!
PostPosted: Mon Nov 30, 2009 7:00 am
What size is that screen? Why that size?
Is that 1/8 x 2 1/2 flat for the pan rails?
PostPosted: Mon Nov 30, 2009 7:05 am
These are prototypes. I am going to make a number of changes but they give you the general idea.
It's very nice-looking work you present here — I'd probably run it if I were building an engine warranting additional oil control.
PostPosted: Mon Nov 30, 2009 9:17 am
I have purchased special orders of that screen because it is fine enough to dissipate the energy and not allow the significant through transit of oil droplets. The crown allows the windage to purge it. If people want some I am more than happy to sell it. It is not a big deal.
No, that is 16g flat steel stock that has been cut and then bent in a brake prior to the studs being installed. The angle of the pan wall is about 78 - 80 degrees and the piece attempts to parallel it.
I use 16g because it is a typical compressed thickness of a standard gasket -- I looked at the compression limiting washers in the Chrysler Turbo 2.5 one piece gasket. With the 2.4 in the SRT4, the gasket is about 2mm thick or 14g.
PostPosted: Mon Nov 30, 2009 1:44 pm
When you use these how do you seal the oil pan to the block with the scraper sandwiched in between ? 2 gaskets or sealer?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Mon Nov 30, 2009 7:12 pm
A high quality silicone RTV -- no side rail gaskets. Ed Peters was suggesting the Mopar rear differential seal as it was formulated for use with synthetic lubricants. Permatex Ultra Gray is OEM rated. Many others are possible.
PostPosted: Mon Nov 30, 2009 8:48 pm
These are going out to Martin.
PostPosted: Tue Dec 01, 2009 4:53 am
Poser
Kevin will you be making more of these? I would be interested in buying after the first of the year. The cookie jar is empty at the moment. :cry: Thanks.
PostPosted: Tue Dec 01, 2009 9:13 am
Yes, I would be happy to. There is more information on the website now.
PostPosted: Tue Dec 01, 2009 11:53 am
I just wanted to thanks Kevin, because I have purchased and payed the regular Up & Donstroke Scraper and not this new design on the downstroke, but he still send me the new one. Thanks again!!!
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Tue Dec 01, 2009 1:40 pm
Geez, really wish I had waited to buy my scraper. Still haven't put it to use and looks really outdated...
-James
PostPosted: Tue Dec 01, 2009 1:50 pm
What benefit, if any would the scrapers have on a totally stock 225?
PostPosted: Tue Dec 01, 2009 4:21 pm
I apologize -- I needed to edit this because I mentioned many other engines than the slant six and that is not allowed here.
Last edited by Kevin Johnson on Sat Jan 09, 2010 12:36 am, edited 2 times in total.
PostPosted: Wed Dec 02, 2009 6:54 am
This sounds like a good addition to any slant looking for a bit more, power mpg, longevity. But we all go to the obvious stuff first ie: exaust and big carbs.
Mecedes is a good comparison, very long lasting motors with good power and mileage in some not so big sizes like the 420sel V8s, and the mentioned Diesels.
