It is currently Fri Nov 27, 2026 8:22 pm
PostPosted: Fri Feb 26, 2010 10:03 am
It's been probably two decades since I last ordered from JC Witless, but it looks like I'm about to do so again (thus guaranteeing another 20 years of my mailbox stuffed with free catalogues, each of which contains an offer to subscribe to the catalogue for only $2 :roll: ).
My '73 Dart 4-door needs new driver's door window channels. The one at the top doesn't seal well, and the one at the front is peeling. Water gets in when I go through the car wash. The question is, which of these is the right one(s)?
(And speaking of that, what're we using for new door weatherseals for the same car? Easy to find new ones for a 2-door…not as easy for a 4-door!)
PostPosted: Fri Feb 26, 2010 11:31 am
I ordered mine from these guys http://www.stanpro.com/. If you click on a part # it will give you dimensions. Pull your old stuff and measure it. Hope this helps.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Feb 26, 2010 12:26 pm
Hey, terrific catalogue those guys have. Thanks! I'm beginning to think nobody makes '67-'76 A-body 4-door door weatherseals, which is kind of...interesting.
PostPosted: Fri Feb 26, 2010 1:24 pm
Contributor
www.restorationspecialties.com has it listed by the foot on page 35 of their catalog.
PostPosted: Fri Feb 26, 2010 2:09 pm
So it seems...but the factory ones on my '73 have different profiles depending on where on the weatherstrip we're looking. I'll give RS a call on Monday and see what they say; my recollection is they're pretty knowledgeable about the Mopars.
PostPosted: Fri Feb 26, 2010 11:41 pm
These guys...
http://www.justmopar.com
...have some stuff listed for the '73 4-door. Is this what you are looking for?
http://www.justmopar.com/store.php?crn= ... how_detail
PostPosted: Sat Feb 27, 2010 7:50 am
Interesting…haven't run into this source before. The description is a little strange ('67-'73? Nooo...should be '67-'76. And where are these '67-'73 A-body station wagons this kit also claims to fit?). And they're not coming from Metro Moulded Parts (who seem to supply a lot of this outfit's other seals); I asked yesterday and Metro don't have those seals. But this is certainly closer than I've come to finding what I need elsewhere. Thanks for the pointer!
PostPosted: Sat Feb 27, 2010 8:10 am
I don't know if this is a good supplier. I was looking around for seals for a '73 valiant a while ago and found this company, but didn't order yet. I think it's strange that the picture shows two seals for a 4-door car.
I did use the JCWhitney window channels and found a good fit, but can't remember what numbers I ordered. If I can find the order I'll let you know.
PostPosted: Sat Feb 27, 2010 11:17 am
I just stripped a wrecked 1975 Valient 4-door a few weeks ago, and paid special attention to those door window weatherseals. You are right, they are different shapes in different areas of the frame. I hate to say it, but it looks like you may have to pull everything apart to determine what you need, unless someone else already has the exact parts info for us. With the parts already in hand, I was going to allow 3 days work at my speed (halffast) to do all 4 doors on a Dart SE with over-stuffed door upholstery. Pat
PostPosted: Sat Feb 27, 2010 3:59 pm
Its a long shot but, McMaster Carr has what they call "Edge-Grip Rubber Seals". They look like door weather striping but may be different.
just a thought hope it helps
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Feb 28, 2010 1:45 am
I can't find the correct numbers for the JCWhitney stuff I used, but I did find out that Dante's lists the lot (seals, channels, whiskers) for the 4-door models.
http://www.dantesparts.com
PostPosted: Sun Feb 28, 2010 8:31 am
Well spotted, Roelof - and Dante's is a known-dependable vendor. Thanks! (weirdness in their listing for the door seals too, tho; they say '67-'72.)
 Post subject: Whiskers
PostPosted: Fri Feb 11, 2011 8:12 am
those from Dante must be made of gold. WOW..
If only I had the time to do what I want to do instead of what I have to do!
 Post subject: Re: Whiskers
PostPosted: Sat Feb 12, 2011 7:29 pm
I ordered all new gaskets from Dante after I had my Dart painted. I compared prices pretty extensively before I ordered, and his prices were VERY competitive.
PostPosted: Tue Mar 08, 2011 6:52 pm
this sucks all i want is window wipe seals and the channel ones. i dont wanna look through pages of stuff. i dont even think i have original channel weatherstrippin ganyways to compare to
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
