It is currently Fri Jan 02, 2026 7:53 pm
PostPosted: Wed Mar 24, 2010 2:11 am
Are these available anywhere?
TIA
--Walt Jackson
PostPosted: Wed Mar 24, 2010 9:01 pm
Try Kanter Motor Products.
PostPosted: Fri Mar 26, 2010 5:47 am
Can someone give me the part numbers for the head gasket and the rear seal? Also the engine set? Both OEM and after market. I will check my source, and see if any are available.
PostPosted: Fri Mar 26, 2010 8:28 am
Here are the OEM numbers out of the Chrysler parts manual for the complete gasket set:
2240 628 up to engine number T-22-4-1
B2240 628 after engine number T-22-4-1
Thanks.
--Walt Jackson
 Post subject: fel-pro gasket
PostPosted: Fri Mar 26, 2010 9:06 am
The # I have for the head gasket set is Fel-pro HS 8000 SH. These are old sets and I don`t no is the number is still valid.
PostPosted: Fri Mar 26, 2010 11:38 am
Misprint. There is no such part number as "B2240 628", and never was. The part number is 2240 628.
Fel-Pro number was indeed 8000 (FS8000SB for full set, HS8000SH for head set).
Victor or McCord (don't recall which) number was 1184.
It's not too hard to find these gaskets; last time I checked, Gerald Letieri and the other gasket specialty houses advertising in Hemmings had them in stock.
Users browsing this forum: Bing [Bot] and 22 guests
