It is currently Thu Jan 01, 2026 11:06 am
 Post subject: vacuum gauge
PostPosted: Sat Mar 27, 2010 1:26 pm
I have a 65 Barracuda that has set for quite a while. I've been on workmens comp for 2 years so can't do a lot to finish my project. Well today is just to nice so I started the car and let her run for a while. Idles OK but a slight miss. I hooked up a vacuum gauge and it reads fairly steady around 17 at idle and goes up to around 27 at 2500 rpm. It varies just a little at idle, maybe a half point or so. I know the valves need adjusting but do those numbers seem To indicate the motors in pretty good shape or not. I think I need to have the valve seals replaced. After running 15 minutes at idle a do have a small amount of smoke from the exhaust.
Any advice, I would be most thankful.
PostPosted: Sat Mar 27, 2010 3:17 pm
How old is the gas and oil? How many miles on the engine? I would change the oil/filter and run out the old gas and try fresh.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Sat Mar 27, 2010 4:43 pm
Gas is old, was in car 2 years ago when I bought it. I added a couple of gallons, Car was last titled in 1986 so I don't know how long it was driven before it was parked. Has new oil and filter, plugs and pvc valve. I have to pour gas in carb to start it after it sits for awhile. I know the tank needs to be cleaned. The carb has been rebuilt. I bought the car in Virginia but it came from Florida. The bodies good and straight but the floors are bad.
Thanks for the feedback.
I do appreciate any help.
PostPosted: Sat Mar 27, 2010 4:45 pm
The car shows 57000 miles. I was told that was correct, but who knows. The numbers do line up perfect and the brake and gas pedal look good.
PostPosted: Sat Mar 27, 2010 5:01 pm
17 at idle is in the low-normal range for a slant six. I would adjust the valves, replace the valve stem seals, and then see what that does for you. I would also check the choke pull-off diaphragm and the vacuum advance on the distributor, for vacuum leaks. That car has been sitting a long time and the diaphragms can dry out and crack.
PostPosted: Fri Apr 02, 2010 10:34 am
That is a fine number if your in gear and idling at 600 rpm. If your out of gear then that is a low number. You should be at least 19" or more depending on age of the engine. Like Ceej says, do a valve lash and see if it will go up. The stock lash at .010 and .020 should net you at least 19" out of gear @ 750 rpm with 6 degrees initial timing. You can squeak another inch of you go up to 10 degrees initial timing.
Some of the valves may have a little carbon or rust or may not be closing all the way or long enough to provide a higher vacuum number. Re-gaping the valves and few days of driving should improve your idle vacuum unless there is a intake gasket leak. Sometimes that will cause a low reading.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
