It is currently Fri Jan 02, 2026 10:39 am
 Post subject: it dont hook up!
PostPosted: Tue Mar 30, 2010 5:42 pm
well ive got my slant all together after about a year and im about ready to fire her up but one problem the stock throttle linkage! i have converted to a holley 390 on an offenhouser intake and its driving me crazy couse i wanna get the car runnin so if yall 4bbl slant owners could help a guy out it would be apreciated very much
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Tue Mar 30, 2010 7:16 pm
Not sure of your actual question. But, if it helps at all, I have an offy intake with holley 4bbl carb, and stock throttle linkage. It will work if you fabricate a new bracket, and the carb is mounted with primaries facing the front of the engine. It works, but not ideal. If you are having length issues, a k-car cable can be made to work, with enough length to mount carb with primaries facing the valve cover.
PostPosted: Tue Mar 30, 2010 7:34 pm
Site Admin
There is a Holley adapter that allows full throttle operation. It bolts to the throttle lever. If your looking for a throttle cable bracket, some of the speed shops have things that can be improvised to work. They are generally made for V8 applications. I fabricated my own.
Are you looking for tuning advice? 52 primaries, 56 Secondary, Purple spring, Orange cam, screw hole #2, 28 shooter, 10.5 PV. That's a start.
CJ
PostPosted: Wed Mar 31, 2010 4:52 am
sorry the question is how do i hook up my holley 390 to my gas pedel and have a bind free linkage?
could ya post some detailed pics of of your set up? ide like to go the cheapist way possable
what about a lokar linkge? would they have enything cut to fit?
thanks ceej i wasnt looking for tuning advice, but that will help me after i get her running and start playing with the carb thanks
PostPosted: Wed Mar 31, 2010 5:52 am
The lokar cable would fix you up!! :shock: with very little work.
We just mounted the 2bbl stock linkage to make the offy and 4bbl work!!
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Wed Mar 31, 2010 1:22 pm
is the lokar kit cut to fit or what?
PostPosted: Wed Mar 31, 2010 8:51 pm
Yep it is. I used it on my clifford + 390cfm 8007 along with the lokar bracket that holds the gas and kickdown cable.
Users browsing this forum: Ahrefs [Bot] and 18 guests
