It is currently Sat May 16, 2026 2:00 pm
 Post subject: Storing a cylinder head?
PostPosted: Mon Aug 30, 2010 3:03 pm
So last week I picked up a cylinder head. The plan is to have some work done on it, but while I plan and save for the work I want done I need to store it somewhere.
Now for the questions...
1) Rust, should I worry about it rusting over the next couple months or is that easy to take care of when I'm ready to get the work done?
2) Best methods to prevent it from rusting? For now I coated the non-painted areas with some oil.
3) What is the best position to lay it down and on what kind of a surface (carpet, wood, cement?) as to not damage anything?
Any advice is greatly appreciated!
'66 Dodge Dart
PostPosted: Mon Aug 30, 2010 3:24 pm
1, 2 and 3, Use LPS#3. Coat it on all sides and stand it on end in a plastic bag.
PostPosted: Mon Aug 30, 2010 3:33 pm
Thanks Ted.
There is already a bit of rust in areas. Will I need to remove the rust first? Also, where do you get a bag that large?
'66 Dodge Dart
PostPosted: Mon Aug 30, 2010 6:27 pm
A big 30 gallon black leaf bag will work perfect.
PostPosted: Fri Sep 03, 2010 2:13 pm
So any suggestions on removing the rust already on the head? I'm leaning toward soaking it in Zep Rust Remover, any objections?
'66 Dodge Dart
PostPosted: Fri Sep 03, 2010 3:51 pm
Chances are the shop you take the head to will hot tank it, hot tanking will clean just about everything off. I would oil the unpainted surfaces,put it in a bag and leave it at that.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Sep 04, 2010 3:31 pm
i agree on the bag and putting it on end but a nice cheap way is rubbing vaseline on it.i use it to store all my parts especialy chrome.the shop will clean it though.
jim
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
Users browsing this forum: No registered users and 16 guests
