It is currently Sat May 23, 2026 6:27 am
 Post subject: stroking the 6
PostPosted: Fri Sep 03, 2010 1:45 am
my van is my baby i take her everywere.she has the 225 slant with the 727 torquflight. i dont want to change my engine .i dont want a v8 ,but its a van and it kind of slacks going up hills.i was wondering if i could do a cam kit ???? or any other options to increase rpm or horespower????mainly if you know what i mean it needs some get up en go.. anything is possible in my book :D
thanks in dvance jim
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Fri Sep 03, 2010 4:27 am
Mill the head, to increase the compression ratio. Best bang for the buck. Helps power and economy, both.
PostPosted: Fri Sep 03, 2010 9:16 am
Vote #2 for a compression increase... and do a little "pocket porting" work and a good valve grind while the head is off.
Have you ever run a compression check on your engine?
If so, what are the current psi readings?
PostPosted: Sat Sep 04, 2010 3:39 pm
well i havent checked the compression ill do tonite .what is the max i can mill the head??.porting sounds good ,oldschool i like it.
thanks jim
PostPosted: Sat Sep 04, 2010 3:59 pm
I took a .1 of an inch off my head most ppl say thats a good compression increase picks up some pep from that
Kev
Users browsing this forum: Google [Bot] and 10 guests
