It is currently Tue Nov 18, 2025 12:10 pm
PostPosted: Mon Oct 11, 2010 9:13 am
Car Model: 1984 D100 Shorty Custom
Since installing the new Cam (kept the bearings) and pump, I've noticed that I really don't get much oil to the rockers, not like I've seen on most others.
If I rev to over 2k I seem to get decent flow, but even then, it seems like there should be more.
I was very careful in swapping cams, and I know the bearings are good. I oiled down the feed hole for the rocker shaft prior to starting.
Is there something else I should check?
~RDE~
President - Cherry City Bombers CC
PostPosted: Mon Oct 11, 2010 10:06 am
Is the rocker shaft installed correctly so the oil feed holes line-up w/ the rocker arm oil holes?
Did you check the cam's oil feed cross hole for correct oreantation?
These can be mis-drilled in the cam and that reduces the amount of flow to the rocker-arms.
The other possibility is that the rear cam bearing is not installed correctly or has rotated, blocking / partially blocking the feed oil holes.
 Post subject: Hmmm...
PostPosted: Mon Oct 11, 2010 7:53 pm
He's using a cam I had used in the BV build.
The holes are drilled correctly. With this cam I did use a Rollmaster timing chain and a Doc Dodge Cam Button (TM)....I wonder if the cam with his silent chain has moved the cam and oiling hole a sukoshi causing a slight restriction...
Users browsing this forum: No registered users and 15 guests
