It is currently Thu Jan 01, 2026 4:46 pm
PostPosted: Fri Dec 17, 2010 11:22 pm
Will the auto tranny from the slant six bolt up to a 318?
I know there are bb/sb only 727's, manual trannies use different bellhousings for bb/sb applications...
I think it has the 904? and have heard that some 904's came with 2 bolt patterns..is this true, and without being able to look at the car in depth right now, how can one tell??
Put your seatbelt on. Im gonna try something
PostPosted: Fri Dec 17, 2010 11:44 pm
6 Pack Dart
The transmissions have different bell housings and will not enter-change from small block to slant six.
Have not ever seen of any dual pattern 904.
Richard
PostPosted: Sat Dec 18, 2010 10:59 am
There are dual pattern slant six/small block bellhousings for trucks with large flywheels, clutches and NP435 transmissions, but no dual pattern slant six/small block transmission cases. There are slant six 727s, I put one in my '74 D100 Club Cab, but a Duster will have an A904.
PostPosted: Sat Dec 18, 2010 9:14 pm
so if Im reading this right, I cant pull the slant six out of the car, and drop in a 318 using the original transmission???
I ask because I was supposed to get this car for $100 a couple years ago...Life happened, and I didn't get it...its been sitting with the carb/alternator off/out...haven't tried to turn the motor yet...I can get a cheap cheap running 318, and drop her into it, just to get it running/driving...
otherwise I would have to assume that for 10+years of the carb being off, either animal debris or moisture has gotten into the engine....
it was supposedly running good, but smoking when parked, but was a daily driver, so a rebuild is necessary anyway....
Hopefully I'll buy it for myself for christmas :D just need a cheap fix (I KNOW I'll have to drain/flush the gas tank, redo the brakes, flush the fluids, and hope the tranny is good)......
PostPosted: Sat Dec 18, 2010 9:52 pm
I'll bet you a penny you can put a carb on that motor, replace the alternator, prime it, and it will start right up. I've heard of slants coming back after worse treatment.
PostPosted: Sat Dec 18, 2010 10:19 pm
I'm a bettin man, and I bet your right :lol:
I already found a running 69 225, for the cost of the car...should I buy the engine first, then the car??? I'm trying to do this with as little money as possible...my 63 d100/440 project bled me dry :oops:
just looking into a slant powered light car, I can fine tune for maximum feul economy :twisted:
PostPosted: Sat Dec 18, 2010 10:48 pm
Heck, buy the whole car, pull the motor, then part it out or sell it whole. Do it all for free in the long run.
