It is currently Mon May 18, 2026 5:53 pm
PostPosted: Mon Dec 13, 2010 11:28 am
Online
I have been reading several recent threads on the Engine page regarding combustion chamber design, timing events, cam shaft theory, and compression ratios, which has piqued my interest in the theory side of engine building.
Do any of you have preferred books covering these topics that you could point me to. I have a copy of Mopar Performance Parts; “Six Cylinder Enginesâ€￾ which is a good practical guide to our slant six, but I’m looking for more of this kind of [url=http://www.popularhotrodding.com/tech/0311_phr_compression_ratio_tech/index.html]stuff[/url]. One or two reference books is a lot easer to deal with than a bunch of web articles.
Bill
PostPosted: Mon Dec 13, 2010 8:19 pm
Sent you a pm
Olaf.
Aspenized
 Post subject: Vizard
PostPosted: Mon Dec 13, 2010 9:36 pm
Although written for "general" performance theory David Vizard's books will help you understand a lot of the why's and how's..."How to Build Horsepower Vol.1" is a very good start (found a used copy at a local book store for 1/2 the new price...)...need to pick up a copy of Vol.2...
Hot Rod used to have a good book that compiled all their old articles on Camshafts, most of the "new tech" in the book is dated, but the theory and dyno comparo of camshaft advances/lobe separation still holds for all the 4 cycle infernal combustion family.
PostPosted: Thu Jan 27, 2011 7:47 pm
how do you like this book , i am thinking about buying it ~~ i also am looking for slant six rebuild information and technical books about the slant six
PostPosted: Thu Jan 27, 2011 9:21 pm
I second Vizard's How to Build Horsepower. There is a new full color version out and I like it. I also have these:
 Post subject: thanks
PostPosted: Fri Jan 28, 2011 4:46 am
thanks ~~ i am just looking for slant six info ( books & technical publications ) want to keep mine stock its in my 87 Dodge B150 van ;
 Post subject: Fsm...
PostPosted: Fri Jan 28, 2011 5:16 am
Then you need a 1987 Truck/Van Factory Service Manual and that will have all your rebuild info and specs for your vehicle and engine.
 Post subject: Re: Fsm...
PostPosted: Fri Jan 28, 2011 9:16 am
Well how about this...jschmid(Jack)on the forum here sent me his no longer need FSM for 1987 Dodge Van.I asked for it because it said 'Van' and I'm nutso for van's.Anyway PM me your address and I'll send it along to you for the same price Jack charged(free!!!)as the 87 I was looking at went bye-bye.Let me know and also a big HATS OFF to jschmid :)
PostPosted: Fri Jan 28, 2011 9:34 am
Online
vanman2:
I have that book. It seams to be light on theory, and heavy on tried and true Direct Connection parts combinations from the past. I think the aftermarket has progressed since its slant six chapter was written.
This is not to say if one follows their outlines for a particular build, it won’t work. But, reading SlantSix dot org leads me to believe the slant six’s performance development is still progressing.
Thanks for your reading list Josh, this is what I was looking for.
Bill
 Post subject: Yep...
PostPosted: Fri Jan 28, 2011 9:30 pm
It makes a good coffee table reader...but the cams are now long gone (and a few board members have had oil gear troubles from MP cams in the past)...
Best rebuild specs/info found in the factory manual (if forged crank a 1976 manual can occasionally be seen on Ebag for $6...if cast crank/mech lifter a 1978 manual is in the same realm...if wanting the paper book.)
Once you go Hipo, this board, the search function and a few books as mentioned by Josh will see you through .
