It is currently Fri May 01, 2026 10:47 am
PostPosted: Thu Feb 24, 2011 6:12 pm
Hi All,
I'm curious how much power folks are putting out on their *street* /6 motors.
I have no idea what mine puts out - but I know that I can go 100MPH up Altamont pass (not saying I've ever done this, BTW). . . without flooring the gas pedal. . .
:D
I may end up putting it on a dyno - I really have no idea what it puts out - BUT I can tell you that Doug truly earned the name "Guru" on this build!!!
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Fri Feb 25, 2011 11:27 am
Sure, right here!!
http://www.youtube.com/watch?v=O4Kl9MBr15o
:P :P
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Fri Feb 25, 2011 1:00 pm
That sounds like an F 18 taking off. :shock:
PostPosted: Fri Feb 25, 2011 3:12 pm
turbo66valiant, What's your engine recipe? what type of gas do you burn?
 Post subject: Dyno
PostPosted: Fri Feb 25, 2011 4:39 pm
About 10 years ago I did up a 225 (street car,standard bore) auto with 3.23 gears. The engine had a .100 milled head, standard valves, mild port work, Clifford intake, 500 afb, Clifford shorty headers,2 1/2 single exhaust with a Flowmaster 40, Petronix ignition. Made 153 rear wheel hp. The guy(running the dyno) said guesstamation 200-208 at the fly wheel. So ?? who knows just a ball park figure.
PostPosted: Fri Feb 25, 2011 7:01 pm
With 10:1 compression, Mike Jeffrey street ported head with 289 Ford valves, Racer Brown ST-14 cam 266 degrees .485 lift, a 500CFM Holley 2BBL, and clifford shorty headers mine made 186HP at the rear wheels. The same engine with a Racer Brown ST-22 cam 276 degrees .505 lift and a Demon 525CFM four barrel made 214HP. This is with an OD 4 speed where the chassis losses aren't as high as with an automatic.
PostPosted: Fri Feb 25, 2011 8:21 pm
Curious were you using the stock cam, Romeo?
63Dart just to give you a baseline, my stock '72 Valiant 225/904 with 2.76er's out back and holley 1920 put 80HP and 140 LB-FT Torque to the wheels. Good enough for a 17.8 @ 75 MPH in the quarter mile. 8)
PostPosted: Sat Feb 26, 2011 4:42 am
My street/strip 170 in a 66 Cuda, dynoed at 358 ft/lbs and 204 hp, at the wheels with the nitrous on. Portable dyno at Pittsburg Raceway, 2006.
PostPosted: Sat Feb 26, 2011 5:02 am
Best dyno with a bad miss... turbo 6 = 296rwhp/381hp
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Feb 26, 2011 7:37 am
Yes stock cam, 340 valve springs
PostPosted: Sat Feb 26, 2011 7:42 am
I remember that Charlie, Didn't you hurt something in the car after that ?
Man , That was 5 years ago already, I think that was the last year for slant racing with Chrysler Classic Events..?
PostPosted: Sat Feb 26, 2011 10:54 am
Yes, I had a nitrous "sneeze", on the run against Ron Hamby, and hurt 3 pistons. Don't really know why. Put three piston/rod assy in from another motor, and that's the way it is today.
PostPosted: Sat Feb 26, 2011 10:24 pm
The race shop I used to work at is installing a new Superflow engine dyno. The owner is begging me to bring out my engine so he can make a few pulls.
PostPosted: Sun Feb 27, 2011 9:33 am
Stock valves, cam, running pig rich blowing black smoke. I drilled the jets on a BBD..........not good.
89HP at the wheels on a portable dyno at the Music City show.
I ran 10.58's in the 1/8th @ 59 mph before the pig rich carb.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Feb 27, 2011 11:15 am
Mike J has spent a ton of time on Bogner's dyno with his stocker motor. He has found that most of the time the stock jets in a BBD are rich anyway.
