It is currently Sun May 24, 2026 2:07 pm
 Post subject: Header flange material
PostPosted: Mon Sep 01, 2003 10:35 pm
On the header flange, does it have to be a stainless steel or will regular steel flat stock work?
Slant Six... out of the ordinary - just like me!
PostPosted: Tue Sep 02, 2003 12:25 pm
You can build a header out of mild steel, but it needs to be *thick* to prevent cracking. It will also be heavy. If you can weld stainless, do that instead. It doesn't have to be thick and will much lighter.
 Post subject: re
PostPosted: Wed Sep 03, 2003 5:02 am
thanks
