It is currently Mon Dec 29, 2025 8:50 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 13 4 5 6 7
 Post subject: Need glasses...
PostPosted: Thu Aug 11, 2011 3:50 am
Grrr. Typed all the text only to be asked my log in again and have all the text erased. Drat!
Okay. Is my eyesight shot? I looked up the Quick Time Performance (QTP) web site list of products and could not find the slant six bell housing for a A833 or T5 or TKO 500/600 or T56. I used the "find" function for "slant" and "RM-7072" and found zero, zip, nada...
Apparently Mal Wood Automotive imports the QTP range of products to Australia and I need (emphasize: need) to know what bell housing I can purchase for the slant six in my race car.
I'm swapping the 904TF for a manual transmission with the engine out for now and ready to proceed with installation once I obtain the bell housing.
So, I need (!) the bellhousing to select the transmission and clutch to fabricate the steel flywheel to bolt to the crankshaft to balance the rotating mass so that I can assemble the short block and fit it all up with a custom cross member and modify the trans tunnel. No pressure here :c
Am I too late and need to fabricate a custom BH? Or is the slant six BH unit a specialty item from QTP that is made from a modular Mopar BH with a suitable transmission adapter plate? Ta
Pentastar Parts and Restorations (PP&R) have a kit of some sort for the slant six with a T5. I wonder what this kit has when compared to the QTP products?
http://www.pentastarparts.com.au/sunsho ... list&c=211
We are thankful and live each day as if we had no tomorrow.
PostPosted: Thu Aug 11, 2011 6:11 am
Best to call Quicktime on the phone. I would be interested in purchasing a bellhousing from them to fit a T56 or 4L60E to a Slant...
PostPosted: Thu Aug 11, 2011 3:10 pm
Car Model: Toad Wagon
Yep, call'em.
The only ones they've made up so far have an adapter ring to suit the factory three and four speed noses. When I got one I was told there was only one other left from the first run. No mention of the timing (or probability) of another run.
The stock number'd been pulled from the on-line catalog the next time I chanced to look. They do carry special order things not in their on-line catalog, so calling'em's the only thing to do.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Mon Aug 15, 2011 10:11 am
it is still on the website if you open up the 'bellhousing application chart' pdf.
scroll to the very bottom, it is the last item on the document.
1969 Dart Custom (great grandmother bought new in '68 )
1990 Daytona running 20psi
2007.5 CTD 3500 Megacab
PostPosted: Mon Aug 15, 2011 8:34 pm
That's good news, I have a couple more folks that'll be looking into'em before long.
Dick, 225% crazy.
 Post subject: T56 & QT Bell Housing
PostPosted: Fri Aug 26, 2011 5:39 am
Thanks folks for the information.
Yep, right at the bottom of the application list it shows the 3 speed and 4 speed bell housing:
http://www.lakewoodindustries.com/Porta ... _chart.pdf
I found out that Mal Wood Automotive here in Australia import the QT bell housings. Next step is to fit one up and see if a T56 will line up.
Here's hoping it can fit with some work and careful attention.
I've read that the bell housing between the slant sixes and the LA V8s are not interchangeable. This should be interesting...
PostPosted: Tue Apr 03, 2012 9:20 am
called Jim Puskas @ 216-688-8300 ext 264
QT has the RM-7072 housing in stock,, quoted 599.95 + shipping
