It is currently Thu May 07, 2026 12:07 pm
PostPosted: Fri Sep 19, 2003 7:29 pm
Ok guys I just bought everything for my super six swap from the local JY. I purcahsed everyting for $50!! Anyways I dont know what the carb cam from though. Its the carter carb, but it doesnt have a tag to tell me what it is. Also what size jets are supposed to be in the slant six?
Thanks
75 duster, factory sunroof and fold down rear seat!
PostPosted: Fri Sep 19, 2003 7:38 pm
A V8 BBD will have 3 screws holding the top plate on and a /6 BBD only has 1. I never re-jetted the 318 BBD on my car and I gained around 2 mpg over the /6 BBD.
PostPosted: Fri Sep 19, 2003 7:55 pm
Here ya go!
PostPosted: Fri Sep 19, 2003 10:13 pm
Usually the V8 carbs have holes in the throttle plates and have a straight tube for the PCV hose while slants usually have a curved tube with no throttle plate holes.
Hope I'm correct.
 Post subject: try for the home game...
PostPosted: Fri Sep 19, 2003 10:47 pm
I can depend on the year for the BBD, I had a 318 BBD off a '74 dart, it had a hole in one throttle plate and a long transfer slot in the other bore. All my super six carbs have no holes in the plates, neither did the BBD off a late 60's 383, oddly enough I also have a BBD off a 1978 318 powered Satellite and it has no throttle plate holes but has the vacuum enrichment circuit you see in '70 Valiant's 318BBD pic....
The variations always are patterned after the options on the car, emmisions and destination of the car (usually Federal, Cali, export, and other states packages...)
It's enough to bake a clerk trying to get a rebuild kit for a carb you have no tag for...
PostPosted: Fri Sep 19, 2003 11:23 pm
I must have gotten an older one. mine doesnt have any holes, and it doesnt have the plate with the one or three screws. Mine has the accelerator pump right there. I think It might be off a 273 or something like that. I think I will try it out, but I doubt it will pass emissions. The guy threw it in with the manifold and stuff for no extra charge, so if I have to go get another one its no big deal.
Thanks for the help guys, and wish me luck
PostPosted: Sat Sep 20, 2003 4:56 am
I just sold a super six last week and that one had the hole in the choke plate.
PostPosted: Sat Sep 20, 2003 8:28 am
I just checked out the carb I pulled from a 318 and put on my /6 it only has 1 screw holding the top plate on. D'ho!!
I guess my way of telling them appart is flawed!
PostPosted: Sat Sep 20, 2003 8:58 am
The only real good way to tell the differance is to meaure the opening for the venturi. The V8 BBDs will be larger. The other way is that the choke lever is differant for a V8 and \6. The V8 BBD will not hook up to the \6 choke rod correctly. Another is if the carb is old enough it will only have a pcv and vacuum advance tubes. This will differantly be a V8 BBD.
These guys claim to have jets and metering rods for the BBD: http://www.carbs.net
That 383 BBD, what is the size of the throttle blades and does it use the the regular BBD bolt pattern?
 Post subject: Big Block BBD...
PostPosted: Sat Sep 20, 2003 9:27 am
I no longer have that one, it sold a while back, I have one off a 440 Dump Truck engine that is a Carter BBD but is "Industrial" looking, THe 383 version looked like the 318 version, but the throttle plates are a smidge bigger and it uses the same flange as the Holley 2210, and Holley 2245 (so fits a 360,361,383,400...not LA blocks...)
PostPosted: Sat Sep 20, 2003 3:42 pm
Hold up a sec-I thought all 2 bbl big blocks and 360's got the bigger non-bbd carburetor. The name of that carburetor escapes me at the moment. I've never even heard of a 383 or 440 with a bbd until now. My '67 fury had the bigger 2 barrel I'm talking about on its 383. It looked nothing like a bbd, and the air cleaner mounting surface was considerably bigger than a bbd. What gives?
Everyone driving slower than me is a moron. Everyone driving faster than me is an idiot. With all these morons and idiots on the road, I can't get anywhere!
PostPosted: Sat Sep 20, 2003 3:56 pm
The slant 6/318 BBD is the BBD 1 1/4", the 360/383 BBD is the BBD 1 1/2". There was also a Holley 2200 series 2 barrel used on some 383s.
Cecil
PostPosted: Sun Sep 21, 2003 7:51 am
I thought that big 2 barrel wasn't a bbd. It was definitely not a holley though.
PostPosted: Sun Sep 21, 2003 9:59 am
It might have been a stromberg. Chrysler used them too.
PostPosted: Sun Sep 21, 2003 12:43 pm
BBD 1 1/4 and 1 1/2 is what Mopar calls them in the service manuals. Most of the fuel circuits are in the same place and, other than size, look the same.
Cecil
Users browsing this forum: Google [Bot], slantzilla and 4 guests
