It is currently Sat Nov 15, 2025 6:02 am
PostPosted: Wed Jan 11, 2012 8:16 pm
This is what I got from NAPA,same size and design as the tan colored one I replaced,but the tip is some other metal(not brass)
time will tell on wear.
1964 Dart GT
PostPosted: Wed Jan 11, 2012 8:21 pm
No problem bud,thanks for the leg work on the cap. I got my cap and rotor on order too!
PostPosted: Wed Jan 11, 2012 10:01 pm
no worries... you gave he info so i had to do something!
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Wed Jan 11, 2012 10:20 pm
:D
PostPosted: Wed Jan 18, 2012 5:01 pm
ok i got my new rotor and cap.. the ca is fine, blue streak with brass contacts...
but the rotor looks to be the same as my duralast junk... i got the MO-3000 extended and looks no different...
did i get the wrong one?
PostPosted: Wed Jan 18, 2012 5:15 pm
Is it tan? It must be tan,and the tip will be noticeably longer when compared to the standard rotor tip.
PostPosted: Wed Jan 18, 2012 5:16 pm
yes it is tan... and next to a durulast its exactly the same...
