It is currently Wed Jun 10, 2026 9:50 am
PostPosted: Wed Feb 22, 2012 3:13 pm
Hello Problem Solvers..
Heres One for ya..
I have a noisy speedometer gear in both my 73 Cuda and the 79 Volare..
The needles work fine registering speed, and the Odometer also works fine registering mileage.. THey are noisy..
Should I grease the cable First???
I think the problem is in the speedometer head itself and I am not afaraid to tear into it.. I just dont want to spray any old wd 40 stuff in there and possibly damage it..
ALso I would rather attempt this repair instead of sending to to bob's speedometer for more $$..
Thanks for any help.
PostPosted: Wed Feb 22, 2012 3:44 pm
the speedo on my 83 D-150 was noisy, but the needle was also jumpy,
I lubed the cable, took it loose at the speedo and tranny connections, flushed it good, has been fine for a while now.
John
PostPosted: Wed Feb 22, 2012 4:39 pm
Greg you got a PM
PostPosted: Wed Feb 22, 2012 9:46 pm
My speedometer was also making kind of a grinding/buzzing noise, different from the noise that a dry cable makes. I don't know about a '73 or '79, but my '67 had a lubrication port on the back of the speedometer head. I put a few drops of light machine oil here, and it took care of it:
PostPosted: Thu Feb 23, 2012 3:57 am
Thanks guys.. When Time allows I will be doing some speedo service..
I think the guts of mine are all plastic without any lube ports :-0
PostPosted: Thu Feb 23, 2012 9:45 am
I've fixed some speedometers, but usually the noise came from the cable, not the speedometer itself.
PostPosted: Thu Feb 23, 2012 10:21 am
As an FYI... The best cable lube for a speedo cable is powdered graphite. Seems like any petroleum based lube either runs-out or gets "gummy" over time, causing future problems.
To do the job "right", disconnect the cable from both ends, pull-out the cable and clean in solvent, then dry it completely. Spray carb or brake clean thru the empty housing to clean it out. (pushing a used cable thru, while spraying, helps remove any dried-up grease)
Coat the cable with powdered graphite and re-install, pour graphite into the housing, as you feed-in the cable.
It is a good idea to change the seal at the trans end (speedo gear to cable seal) to prevent trans oil from getting into the housing and mixing w/ the graphite.
DD.
