It is currently Tue Dec 30, 2025 11:07 am
PostPosted: Fri Oct 24, 2003 1:17 pm
So, I posted about this once before but this is a specific thing this time. My power steering has leaked since I got the vehicle, but tightening certain bolts kept the leaking down to a minimum. Well yesterday morning I went to tighten them and I tried tightening something else and the screw itself broke in two and the half that was plugging the hole fell out and so now there's a massive hole and it doesn't retain any fluid. My question is, is it bad to run the car with no power steering fluid? it's like manual steering, I guess, I just gotta put some effort into turning the wheel. But will it inflict major damage on my power steering? SHould I take care of it like NOW or ASAP or would next week be okay? Thanks for the info.
PostPosted: Fri Oct 24, 2003 1:37 pm
If you take the belt off the pump you could run it for a short period without damage.
Once all the fluid drains-out there will be no lubrication for the moving parts, at that point things will gull-up and/or seize.
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
