It is currently Wed Dec 31, 2025 1:45 am
 Post subject: What gives??
PostPosted: Fri Oct 24, 2003 4:26 pm
I want to know the difference between the hyper pak and the super six setups??
And also, I want to buy a 833-o/d trans and a 225 six. Do I just keep searching e-bay and letting people sniper bid me at the last second, or is there another resource.?? I have been looking in the local pennysaver and e-bay. I would look in the local wrecking yards, but I really don't know what I'm looking for.
I bought my Dart as a money making opportunity,(i got it for cheap) and now were hooked. I want to make it my daily driver. This is why I have so many questions.
Thanks again-Josh
Hellbent Rods & Custom fabs
PostPosted: Fri Oct 24, 2003 4:48 pm
SSRN National Champion
The Hyper Pak came on early MOPAR Slant Six engines and were built to run at Daytona, they did and blew all the other brands away. It had a four barrel intake with special runners and a Carter four barell carb. These are rare pieces now and are expensive to purchace.
The Super Six set up came out in the mid seventys and had a two barrel intake and carb. These are not so hard to find. But there is not a big performace gain by going to a super six setup than a stock setup. Find an Alluminum one barell intake and put the one Barell Holley that came with the six and it will work fine on a stock engine. I have tried all setups in the last six years and will try to help you Thanks Possum Parker. :D :D
gone bagel bagging back in 12.60 seconds
 Post subject: finding a 225 ??
PostPosted: Fri Oct 24, 2003 7:30 pm
I found one via the local paper (thrifty ad section) I found another by a visit to the local WPC (walter p Chrysler) chapter. The auto wrecking
yards are another source. I have a rebuildable block and head if you want them. They were running but need the head surfaced and block decked since the head gasket let loose after a few thousand miles - The price
is right though - just come pick it up (if you are going to dump your 170
or 198 you could leave it in trade :D )
I have not tried finding any transmissions yet - but would assume the same places would work.
PostPosted: Fri Oct 24, 2003 9:26 pm
Relic-lover,
You have a private message :wink: :wink:
PostPosted: Sat Oct 25, 2003 8:17 am
Here is a photo showing some of the Slant Six intake manifolds, the super Six 2 bbl is the one 0n the lower right.
http://www.dutra.org/pictures/engine/pa ... pgroup.jpg
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
