It is currently Sat Jun 20, 2026 11:04 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: here we go again
PostPosted: Wed Oct 29, 2003 10:34 am
I am thinking Headers for my slant it is a 70 dart super six ele. fan and ign. and its a daily driver anyone have headers on their daily driver?wich ones?? and if i do go with headers is it a smart move if i do alot of long distance driving?
thanks
PostPosted: Wed Oct 29, 2003 6:22 pm
I have had headers on my daily drivers for quite a while. I had Mopar 6X1's on my Duster, and Clifford 6X1's on my '66. Never had a whole lot of problems with either set. :shock:
PostPosted: Wed Oct 29, 2003 7:04 pm
what does not quite alot mean :shock:
PostPosted: Wed Oct 29, 2003 7:28 pm
Make sure they come ceramic coated if they are going in a driver car or they eventually will rust out. Use some nice thick clifford or cox bros gaskets and make sure the flange isn't warped before you install it.
Other then rust and getting them to seal on both ends I don't see why you would have anything to worry about.
PostPosted: Wed Oct 29, 2003 7:41 pm
are the mopar ones good,i just dont want to go and spend alot of money and have $#!+ if you know what i mean :shock: anyone else have headers on there daily drivers??
PostPosted: Wed Oct 29, 2003 8:07 pm
I have clifford 6x2 on my daily driver pickup and have had zero problems except for rust.I really wish I would have had them coated but you live and learn.Dutra duals are another option which Im using on my 60 Valiant.
Slant6ed Attitude
PostPosted: Wed Oct 29, 2003 8:10 pm
Someone needs to cast a header as thick as a typical manifold. That would be the best of both worlds but quite heavy I would think. Maybe out of some other lighter weight material.
 Post subject: thin cast
PostPosted: Thu Oct 30, 2003 9:32 am
i don't know much about casting but i think thinner materials would crack easier, that's why cast iron is thick... I think tube headers are best with some sort of coating on them, also it's nice to use some header wrap, wherever it's easy to get the stuff wrapped on.... once you get headers to fit (few hours putting dents/dimples in - use 2 hammers - one ball peen for the denting and one to strike the other hammer) they are good to go. Even ones without coatings that get rusty will last a long time...
if you want to got the cheap route, use Bill Hirsch Coatings header/manifold paint (don't use VHT header spray paint or any automotive store header paint) http://www.hirschauto.com/ it's best to sandblast or beadblast the header before painting with this stuff
http://www.hirschauto.com/acb/showdetl. ... 11&CATID=1
PostPosted: Thu Oct 30, 2003 12:25 pm
I've been told by others online and by the guy who ceramic coated my headers that wrapping isn't a good thing. It either a) holds so much heat inside the header they can melt itself or b) holds moisture against the header so they rust even faster. Just sharing a thought.
I was just imagining something like Docs Duals, but cast into the shape of a clifford. I wonder how much that would weigh.
 Post subject: Hyper pak exhaust
PostPosted: Thu Oct 30, 2003 1:56 pm
How about the original hyper pak exhaust manifols with a little bigger cross section? They were pretty nice looking
Rick
PostPosted: Thu Oct 30, 2003 2:04 pm
Do you know where i can find one of theese manifolds??
PostPosted: Thu Oct 30, 2003 6:44 pm
Yes, do you have $2200?
PostPosted: Thu Oct 30, 2003 8:29 pm
Maby is this for the whole hyper pack?
PostPosted: Thu Oct 30, 2003 9:01 pm
Whats the difference between the "whole" hyperpack and just the manifold? The carb maybe? And thats what, $300 new? ;)
The price for an original hyperpack manifold is high because of how rare it is.
PostPosted: Thu Oct 30, 2003 9:13 pm
no we are talking the hyper pack exaust manifold
