It is currently Sun Dec 21, 2025 9:22 pm
Post new topic  Reply to topic  [ 134 posts ]  Go to page Previous 15 6 7 8 9
PostPosted: Wed Jul 11, 2012 4:44 pm
The clip is almost a complete circle but has two little legs sticking up on the ends. You must grab one of those legs and carefully pull the clip out. Be careful because the clip (a) distorts and (b) might go flying who knows where. Putting this little bugger back in can be tricky too. I like to use a small flathead screwdriver and work the clip back into its groove.
This will all make sense once you are looking at the distributor.
Go slow, and you should be fine. Good luck!
JC the name for the item is a Jesus Clip, the reason being is when it makes a tiny little sound it has a better disappearing act than Hodini himself and you are there saying JEEESSUUSS where did it go. ( altho some are shaped a little differently than others they all end up being the same.... MISSING) ;)
Reed you could have told him that the proper tool to use is snap ring pliers, but most of the time you can get by without them... :lol:
We dont want to keep him totally in the dark, as he is having so much fun learning.. :wink:
MRO....
PostPosted: Wed Jul 11, 2012 4:52 pm
Snap ring pliers work on that clip? I didn't know that. I always use needle-nose pliers to pull it and a small flathead screwdriver to reinstall. I'll try snap ring pliers next time.
PostPosted: Wed Jul 11, 2012 5:24 pm
Car Model: 1967 Dodge P200 Post Office Vehicle
You are doing fine, much better than I did the first time I got this deep into a motor.
Hey Reed,
Have Lorrie's Distributor partially disassembled. There doesn't seem to be anything amiss in it. Nothing broken or terribly worn.
Removed the Screw that held the Condenser in place.
Removed the Screw that held the Points set in place.
Removed the Condenser and Wire from the "-" Terminal of the Ignition Coil from the Points set.
Removed the two Screws that held the Vacuum Chamber in place.
Removed the Vacuum Chamber from the two pieces that make up what the diagram in the Dodge Manual calls the "Contact Plate".
Removed the little Clip that held the two pieces of the Contact Plate together.
Separated the two pieces of the Contact Plate.
There are some spots of rust on them, but nothing serious looking.
The only strangeness so far is that when handling the unit, all of a sudden a brass Nut the size of the Nut that holds the Condenser and the Wire from the "-" Terminal of the Ignition Coil in place fell out of the Distributor Base.
So far have not been able to see or find any place from where that Nut could have come loose, and surmise that it was a Nut used to hold the Condenser and Wire to the Points Set, and that someone (probably a USPS mechanic) had dropped it into the Distributor, and instead of fishing it out, just installed another Nut and let it go at that.
And the only anomaly that MIGHT not even be an anomaly is that one of the Springs on the Centrifugal Weights is a heavier gauge Spring with less coils than the other one.
Disassembling and cleaning a distributor is not technically difficult, but can be difficult the first time you do it.
This one is coming apart quite easily, but am not all that deep into it yet.
I am posting scans from my 1983 factory service manual detailing how to disassemble a lean-burn ignition distributor. Disassembling a points distributor is virtually the same. The only special tool you need is a pair of fine point needle-nose pliers to pull a little clip out of the center of the shaft.
That would be the "Snap Ring" under the "Felt" in the top of the Shaft Assembly.
I don't think the diagrams I am posting show it, but immediately below the rotor there should be a little felt pad, followed by this little "O" shaped clip. The clip is almost a complete circle but has two little legs sticking up on the ends. You must grab one of those legs and carefully pull the clip out. Be careful because the clip (a) distorts and (b) might go flying who knows where.
Is there REALLY any reason why that NEEDS to be removed, seeing as to how this unit is NOT going to be used in the HEI Conversion?
BTW, have just received a response from Ray Orme, to whom an E-Mail was sent. The text of that E-Mail is as follows:
Dear Sir,
Am looking for a NOS Dodge Slant Six Electronic Truck Distributor.
Daniel Stern at the SlantSixForum recommended that I check with you for this
item.
It is going to be used in Lorrie Van Haul, who is apparently the only
surviving 1967 Dodge P200 Postal Van in existence.
Would like to know if you have such an item, what it would cost, and how
much the shipping would be to Onalaska, Texas which is thirty-three miles
East of Huntsville, Texas.
Thanks in advance for assistance in this matter.
JC Allison
His response is as follows:
Yes, we have them in stock. They were destined for the assembly line and include cap and rotor. Cost $90. each. Questions: Please call (206) 300-1083. Thank you.
Will probably NOT take it out since the Distributor that is to be obtained from Ray Orme will be a complete NOS Electronic Truck Distributor.
Yes.
Here are the scans:
Got them.
I would clean all the bits and pieces in your favorite solvent and check the shaft for excessive wear and play.
There doesn't seem to be any wear or play in the Shaft.
Your distributor will have a vacuum advance pod not shown in the above diagrams. It unscrews from the body of the distributor and has a little arm with a stud that fits into a hole on the plate supporting the points. It is fairly obvious how to remove it once you are in there.
Yes. Have already removed it, replaced it (to make sure that it can be reassembled), and then removed it and set it aside.
Be sure to check that the vacuum advance pod still holds a vacuum. If it doesn't, you will need to replace it.
It seems to be fine. Found it to be amazingly tight, but it DOES work.
I would put the springs and weights and governor in a bag and save them for your new distributor.
Actually, as noted above, the Distributor that is coming from Ray Orme is going to be a complete NOS Electronic Truck Distributor, so the Weights and Governor won't be needed for the NEW Distributor.
When your new distributor arrives, you can disassemble it, clean it, and reassemble it with the springs and weights and vacuum advance can from your original distributor.
Won't be necessary.
Thank you.
Reed, something that was noticed: The Points Gap was set at 0.020. And the Hex Cam on the Shaft Assembly would open the Points to that Gap. BUT the Points actually came open about only 1/16 of an inch BEFORE the apex of the Hex was reached, and then closed 1/16 of an inch AFTER the apex of the Hex had passed. This geometry seemed to me to give an excessive amount of Dwell.
Am going to make a CorelDRAW Diagram of a Hex with the Specified amount of Dwell indicated, and see if what this Distributor is doing is within THAT limit. It MAY be that the Hex is over-worn.
The bit of fantasy writing to which you responded with all the bananas was actually written for the guys over at the FordMuscleForum, and was meant to kind of break up the intensity of dealing with this Lorrie Problem. Am afraid it didn't set well with them. :( Sometimes one just never knows.
Anyway, thanks for the assistance. Have some questions about the HEI Equipment, and when it is all formulated would like to run it past you to see if what is found is going to be what is needed. But at this point am still finding stuff, and learning about the HEI Ignition System.
Thanks again for the help. Will be in touch.
JC
Lorrie Van Haul - 1967 Dodge - P200 Post Office Vehicle - 225 Slant Six - Torqueflite A727 Automatic Transmission - Right Hand Drive Steering - Big Three HEI System - Frantz Oil Cleaner System - Bendix Stromberg Model W Carburetor
PostPosted: Wed Jul 11, 2012 11:48 pm
That 4.74 volts after the ballast sounds too low............
PostPosted: Wed Jul 11, 2012 11:55 pm
What's the resistance of the ballast and the coil?
PostPosted: Thu Jul 12, 2012 5:38 am
Hey Mr. E,
What SHOULD it be?
JC
PostPosted: Thu Jul 12, 2012 5:39 am
Hey Mr. E,
Don't know, but could check a bit later on today.
JC
PostPosted: Thu Jul 12, 2012 7:44 am
Hey All,
Here is a GIF that shows the difference between the Dwell specified in the Tune-Up Specification for Lorrie's Distributor and the ACTUAL Dwell that was in Lorrie Distributor.
The Red area is approximately the amount of Dwell that Lorrie's Distributor had with the Points Gap set at 0.020.
The Yellow area is the 45 degrees that is specified in the Tune-Up Specifications. Actually, the Tune-Up Specifications say 40 to 45 degrees.
To get 40 to 45 degrees, the gap would have been MUCH more than 0.020.
It appears to me that the Rub Block on the Points Set is too short, OR that maybe the Hex Cam on the Distributor Shaft Assembly is worn.
Anyway, it is a moot point since we are going to be going to an HEI Electronic Ignition System.
BTW, the hexagon is a bit distorted because of the CorelDRAW file being exported to GIF, but it accurately shows the difference between Specifications and Actuality.
JC
PostPosted: Thu Jul 12, 2012 8:06 am
Hey Dusty,
There are a number of devices that have Jesus Clips!
HEY! I happen to have a very nice pair of Snap Ring Pliers. They are REALLY spiffy. They have a removable Screw that one can take out, reposition the two parts of the Pliers and they will remove External or Internal Snap Rings depending on where the little removable Screw is placed.
We don't want to keep him totally in the dark, as he is having so much fun learning.. :wink:
It's an hour-to-hour, ever-changing, minute-to-minute, custom-made, second-to-second experience.
JC
PostPosted: Fri Jul 13, 2012 1:18 pm
Hey All,
Have done some research on the effects of Insufficient Dwell, and Excessive Dwell.
Lorrie has a Catch 22 situation as far at THAT is concerned.
The amount of Time that the Points are OPEN and the amount of Time that the Points are CLOSED is not measured in Clock-Tick Time, but is measured in Degrees, and can vary in Clock-Tick Time due to varying Engine Speed.
Dwell Time is actually the amount of Degrees that the Points are CLOSED!
During the time that the Points are CLOSED, the Ignition Coil is building up its Charge.
When the Points open, the Charge in the Ignition Coil fires off to the Distributor.
If the Dwell Time is EXCESSIVE, the Spark MAY be larger, but the Rotor will already be PAST the Distributor Cap's Spark Plug Terminal when the Coil fires off to the Spark Plug.
Conversely, if the Dwell Time is insufficient, the Spark will be too small to fire the Spark Plug adequately.
Lorrie was experiencing EXCESSIVE Dwell Time.
The Symptoms of EXCESSIVE Dwell Time are:
Idles fine, but won't rev up.
Rough running.
Unburned Fuel builds up in the Cylinders.
Spark Plugs foul.
Sound familiar?
The previously mentioned Catch-22 is that:
Lorrie can have PROPER Point Gap, but will will have EXCESSIVE Dwell Time.
OR
Lorrie can have PROPER Dwell Time, but will have EXCESSIVE Point Gap.
But she CAN'T have PROPER Point Gap and PROPER Dwell Time together.
The Geometry of the Distributor Shaft's Hex Cam, and of the Points Sets that are available just don't allow for it. As far as I can tell, the Rub Block on the Points Set is too short.
The Tune-Up Specifications of 0.017 to 0.023 Point Gap results in EXCESSIVE (50 to 55 Degrees) Dwell Time.
The Tune-Up Specification of 40 to 45 Degrees of Dwell Time results in EXCESSIVE (0.035 to 0.040) Point Gap.
Am hoping, and believe that the HEI Electronic Ignition System will SOLVE this dilemma.
Hope you all are relaxing and having a WONDERFUL time.
JC
PostPosted: Sat Jul 14, 2012 9:45 am
Hey All,
Saturday Afternoon Update:
Have Lorrie's Distributor partially disassembled. Am cleaning it up, and will reassemble it.
Attach the dwell meter, crank the engine, adjust dwell while cranking. Now check the gap.
This may or may not happen, depending on how efficiently the parts for the NEW HEI Electronic Ignition System arrive. The ECU (Electronic Control Unit) has already gotten here.
From examining the ACTUAL Distributor, it appears that in order to get the proper Dwell which is a function of the Hex Cam to Rub Block interstice, and the present configuration of the Rub Block is what is preventing the Distributor to fulfill its capability of keeping the Points OPEN and CLOSED for the proper number of Degrees. ,
It is not though that one can accurately measure the opening time by eye.
While this is probably TRUE, the determining of the position of the Hex Cam's Ramps and Apexes, and their relation to the Rub Block part of the Points Set CAN'T have THAT much difference between what an electronic instrument indicates would be the relationship, and what a reasonably aware person looking directly AT the mechanism using optical magnification.
And there is a significant possibility that doing what has been suggest would result in Lorrie being up and running again again. That is, IF the OLD Distributor is properly reassembled, which there is no reason to believe that it wouldn't be, but one never knows.
There is so much to learn about these OLD Systems. Have found that present day mechanics, like the ones that are running the auto repair shops, have little knowledge, and even less affinity for wanting to know about the OLD Systems, leave alone be willing to actually work on one of them.
So MY being this deeply involved with Lorrie serves the purpose of keeping life interesting, but what is even more tangible is that the "fixing-up" of Ms. American 3.14159, and Lorrie Van Haul, is out of the necessity to have reliable transportation.
The "tipping" point at which it was decided that working on keeping Ms. American, and Lorrie Van Haul up and running reliably happened when it was decided that it wouldn't be just out of necessity, but that it would actually become a hobby.
And since then, the learning about, and the gaining of the expertise, and skills necessary to deal with the procedures and processes that make all of these OLD Systems work as they did originally, has gone on apace.
Am getting better at doing this kind of thing, but there is so much that is not known.
Anyway, the goal is to make Ms. American 3.14159 and Lorrie as reliable as they can be, while doing the work with as much precision and care as one can muster. Am not hurrying, am not settling for just good enough. This is a hobby and as such qualified to be scrutinized as closely and as deeply as one can possibly accomplish..
But you know what? One can read how to deal with these OLD Systems, but that doesn't mean that one UNDERSTANDS how they work.
Even though the person writing the explanation knows perfectly well what he is saying, HOW to deal with one of these Systems isn't always transmitted from the person writing the instructions to the one receiving the transmission.
I read pretty well, and some explanations make perfect sense, so it isn't that somehow it is the fault of the person not getting the knowledge. Sometimes there is a problem with the actual understanding of what is written.
The problem is that: What is written, while true, doesn't transmit the actual knowledge.
It takes handling the actual parts themselves to have what is written make any sense.
So that's what is happening here.
Not only are we becoming familiar intellectually with the system, but actually dealing with the parts and pieces that go to make up the System,
It comes under the heading of someone not understanding the instructions because the transmitter/receiver system somehow fails in its attempt to make the information jump from the page (or monitor), to the reader's knowledge bank.
But once the subject is learned intellectually, then contemplation and concentration can take place.
Was contemplating the functioning of the OLD Ignition System last night.
A number of the functions of this OLD System came into question. One question was WHY do the various functions happen?
Most of the Distributor Mechanism is very straight forward, and easily understandable.
Other functions seem either mystical, Incidental, or actually useless. But that is just from LOOKING at the Mechanism itself.
And the question arose:
Are there parts of the System that do a certain thing because they were designed to do that certain thing? Was it REALLY supposed to do THAT (whatever something) as part of the functioning of the System?
OR: Does it just happen like that when the System functions?
For example:
When the Points come open, there is a SPARK that occurs between the Points. Is there a REASON that the System is designed have a SPARK between the Points when the Points are open?
OR: Is THAT just what happens when the Points come open?
If there IS a reason for the Spark, WHAT is it?
Thus began a contemplating of the WHOLE System, noting along the way the functions that are not understood.
For Example:
To start with, the Electricity comes FROM the Battery , but while running, the Electricity comes from both the Battery AND the Alternator.
The Electricity goes into the Ignition Coil at the "+" Terminal of the Ignition Coil.
What happens inside the Ignition Coil is predicated on the functioning of the elements INSIDE the Ignition Coil.
When just maybe eight or nine years old, took an OLD Ignition Coil apart to get the really LONG Copper Wire out of it, which was strung between and around a number of trees, and was used as an aerial for a "Crystal Set", which was an early form of Radio, and at the time the "scientific" world was being explored at school, and one of the projects was a "Crystal Set".
At the time, it wasn't on my mind to see how the Ignition Coil was constructed. So to this day, I haven't the slightest clue of WHAT is actually IN an Ignition Coil, and HOW it works.
But to continue on, apparently the Electricity goes into the Ignition Coil's "+" Terminal, and comes out of the "-" Terminal to the Points Set, which is connected to a Capacitor, commonly referred to as a Condenser.
There is Electricity going to the Condenser, and this continues to do so, till the Distributor Shaft's Hex Cam acting on the Points to which the Condenser is attached, opens the Points, and somehow, the opening of the Points causes the Condenser to discharge.
And the Condenser being connected to the "-" Terminal of the Ignition Coil, SOMEHOW creates a shot of HIGH Energy to the Ignition Coil, which responds by putting out a relatively LARGE amount of Electricity out of the Tower of the Ignition Coil, through a Wire to the Distributor, which routes it to a Spark Plug, the tip of which is designed to be able to create a SPARK at the PROPER time and at a PROPER rate to make the Engine run.
Though not FULLY understanding HOW the OLD Ignition System that existed in the contemplation works, got to watching it function in my mind.
This build-up of Electricity in the Ignition Coil, and the Condenser, and then the release of all that Electrical Energy at the PROPER time, and PROPER rate goes on, in a Six Cylinder, Four-Cycle Engine, turning 1,000 RPM at a rate of 250 times a minute for each of Six Cylinders, which is at the Points, a rate of opening and closing 25 times a second. At 2,000 RPM it would be 50 times a second. At 4,000 RPM it would be 100 times a second.
But it's one thing to KNOW how a system works, and it is quite another thing to UNDERSTAND the nature of this OLD System.
The OLD Ignition System is a throbbing, humming, surprised-that-it-works, set of parts that do what they do acceptably well, being reasonably reliable and trustworthy.
The level of UNDERSTANDING of this OLD System depends on a bunch of elements:
But, at the deepest levels of understanding, one ceases to be involved in just the "Old Car Hobby", but one has become involved with the Electric/Electronics like Nicola Tesla.
Nonetheless, there are questions that need answering. Not only intellectually through verbal or written information, but in REALITY with the ACTUAL pieces of the System in hand, assembled properly, and adjusted correctly.
For example:
HOW does the Coil take IN the Electricity that it does, store it for a precise time, and then what makes it RELEASE its energy?
I know what CAUSES it to do what it does. I just don't know WHY it does THAT!
Another Example:
The Spark in the Points Gap. Why does it SPARK, and wouldn't the transmission of the Electricity be more efficient if it DIDN'T spark?
So the question becomes:
Is the functioning of the System dependent on there being an actual SPARK between the Points while they are open? And if so, WHY? OR is it that when the Points come open, the Electricity just naturally arcs across that Gap?
Anyway, just noticed that there was a package from Amazon delivered, and it turned out to be the Electronic Control Unit that was ordered for Lorrie's NEW HEI Electronic Ignition System.
Here we go again!
Am going to have to come to grips with not only the concept of the NEW HEI Electronic Ignition System, but also with the REALITY of having one's hands on the ACTUAL System components.
Isn't this FUN?
JC
PostPosted: Sat Jul 14, 2012 11:51 am
Hey All,
For example:
For Example:
For example:
Another Example:
DEEP JC.... Very DEEP
Here we go again!
Isn't this FUN?
JC
Ummm a question JC, WHAT ECU are you referring to? When doing the HEI CONVERSION there is NO ECU, But a module instead... IE Parts needed for a HEI Conversion:
A GOOD GM Module. (Chrysler uses a ECU "box")
AN E-Coil
A Plain Vanilla Electronic Distributor w/ Vacuum Advance.
Plus various lenghts of wire and a few connectors.
A wiring diagram of sorts.
OPTIONAL: Some form of Heat sink/mounting bracket for the Module and coil.
And the relay that SSD Recommends, but isnt a deal breaker if you dont have or want to use one.
MRO....
PostPosted: Sat Jul 14, 2012 12:49 pm
Was just wording where my contemplation had taken my awareness.
OH! My bad! I added the words Electronic Control Unit (ECU) to the description that is on the Instruction Sheet that came with the Standard Brand LX301 Control Module.
A GOOD GM Module.
The one that is here is for a GM System.
Well, you see? There you go. Learned that the Control Module is NOT an ECU!
AN E-Coil
Standard BlueStreak #FD-478X $38.74
Chrysler Electronic Ignition Distributor w/ single pickup, vacuum advance.
NOS Slant Six Electronic Truck Distributor. $90.00 + Shipping. Ray Orme <ocpnwi@gmail.com>
Plus various lenghts of wire and a few connectors, a wiring diagram of sorts.
Will find out what is best, and possible at some time in the near future.
Anyway, no PMs or E-Mails from you at FMF or here.
Am starting to fade. Need sustenance. Later.
JC
PostPosted: Mon Jul 16, 2012 7:27 am
Hey All,
Monday Morning Update.
Got Lorrie's OLD Distributor cleaned and reassembled.
Have learned:
LESS Points Gap = MORE Dwell.
MORE Points Gap = LESS Dwell.
QUESTION: If the Dwell Angle is correct, does the width of the Points Gap matter?
The reason for asking is:
Lorrie's Points Gap is listed in the Tune-Up Specifications as: From 0.017 to 0.023 Inches.
Lorrie's Dwell Angle is listed in the Tune-Up Specification as: From 40 to 45 Degrees.
From observing Lorrie's Distributor, a static, physical Dwell Angle of 45 Degrees results in a Points Gap of about 0.035 Inches, and a Points Gap of 0.023 Inches results in about a 50 to 55 Degree Dwell Angle.
This was ascertained while Lorrie's OLD Distributor was being partially disassembled, cleaned and re-assembled, by doing some measuring of the interaction between the Distributor Shaft's Hex Cam, and the Points Set.
Am thinking about putting Lorrie's Old Distributor BACK into Lorrie and seeing if Lorrie's mighty 225 Slant Six Engine will run with a bit MORE Gap, and a bit LESS Dwell Angle. If it will run, then would adjust the Dwell to the proper setting with a Dwell Meter, and then measure the Points Gap.
Am suspecting that possibly the problem that Lorrie had been having was the result of EXCESSIVE Dwell due to having the Points Gap set at only 0.020.
Have another question.
When Lorrie's OLD Distributor was disassembled, it was noted that Contact Plate assembly has three Brass Stanchions which hold the Upper and Lower Plates apart, yet still permit the Upper Plate of the Assembly to be moved in relation to the Lower Plate by the functioning of the Vacuum Chamber.
QUESTION: Does current pass through those Brass Stanchions?
The reason for asking is: Where the Brass Stanchions on the Upper Plate contacted the Lower Plate, there was "build-up" of what could have either been corrosion, OR maybe some kind of contaminant, such as would accrue if some form of lubricant had gathered some amount dirt/grime/grit/etc. around the Brass Stanchions.
Also, the ends of the Brass Stanchions are slightly "pitted" indicating that electricity is passed through them.
That "build-up" was removed from the Lower Plate, and the Brass Stanchions were cleaned.
It could have been that IF the Distributor uses the Brass Stanchions as the path for the Electricity to reach Ground, that THAT could possibly have been the cause of an intermittent interruption of current.
Anyway, that's it from here.
Any enlightenment on these two questions would be much appreciated.
Thanks in advance.
JC
