It is currently Mon Jun 15, 2026 2:17 pm
 Post subject: no fuel to the engine!!!
PostPosted: Tue Sep 04, 2012 6:26 am
boy, yesterday was a doozie.
on our way home, my engine died. luckily, the freeway aid guy came along and helped me diagnose the problem which was that the fuel pump wasn't working, and towed me to the nearest o'reilly. on the way there, he suggested i get a universal electric fuel pump to get me home, rather get towed all the way back to the east bay (we were about 15-20 miles from home).
i got the pump, bypassed the bad one and it fired up. great! we jumped in and left. in my haste to leave, i forgot to reconnect the #1 wire which i disconnected to give me more room to work. the engine obviously had a miss, but i was too happy to be back on the road to pay any attention to it. it was getting late and i needed to get the family home.
well, half way there, as we were crossing the bay bridge, the engine quits again. once we got off the bridge (we coasted a good mile - glad i adjusted the front brakes - ) i checked the pump, it was still making it's buzzing sound, but no gas was getting to the carb.
i haven't been able to look at the car yet, but after checking the lines for kinks and such, what else should i be looking for? is there some sort of float in the tank that can get stuck? i do have a non haynes/chilton manual, which i will be consulting. it is just clear to me that there is knowledge, not available in any manual, that i can glean from this pretty awesome forum.
oh, i filled up two days ago and have a locking gas cap.
thank you in advance
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Tue Sep 04, 2012 8:23 am
One place to check is at the pick-up tube in the tank. I have had these clog up enough to cut off fuel flow (esp. under load.) You will need to make sure the tank is less than half full before removing the sending unit/ pick-up tube.
There may be other solutions, but that's the one that comes first to my mind.
Good luck!
. . . there was good sport at his making.
PostPosted: Tue Sep 04, 2012 9:50 am
I am guessing you put the electric pump somewhere in or near the engine bay -- that's not where an electric pump goes; they're pushers and not pullers so they need to be back by the fuel tank. They'll work as pullers for a little while -- kinda -- but not for long. Remove the electric pump and go back to the correct mechanical one.
PostPosted: Tue Sep 04, 2012 10:48 am
that is correct, i stuck it right on top of the mechanical pump. i had no idea about the push me pull you differences, and didn't have the time/tools/wherewithall to do it correctly. so you kind of answered my next question about keeping the electric pump - it cost $80 but i guess it's going in to the parts bin.
are there good rebuild kits for the mechanical pump? does any one have experience with the new pumps from o'reilly?
i guess now would be a good time to do the fuel line mod as well 'cause i twisted the line from the old pump to the carb.
thanks!
is there anything i need to worry about regarding running my engine on 5 cylinders? it was for about 10 miles, on the fw.
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Tue Sep 04, 2012 10:52 am
You probably washed that dead cylinder down (with fuel) pretty well. Might be a good time to change your oil.
- Mac
PostPosted: Tue Sep 04, 2012 11:51 am
I am not a fan of electric fuel pumps on carbureted engines. They tend to cause more problems than they solve. But if you do wind up keeping the electric pump (and installing it where it belongs, back by the tank) then the system needs to be designed correctly or you create very serious safety hazards.
Only for the '60-'63 bolt-together type pumps. The '64-up crimped pumps cannot be disassembled or rebuilt.
Be picky and choosy. Reject a pump made in China.
Yep.
It'll be fine.
PostPosted: Tue Sep 04, 2012 12:54 pm
I heard that... ahem, hear hear. Most of the broken things around the house are made in China.
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Tue Sep 04, 2012 6:32 pm
Is it one of those cubish electric pumps?
They work with an internal check valve and can be used with the mechanical pump even if they're off.
I use one by the tank to prime the fuel system if the car hasn't been used for awhile, and then turn it off.
PostPosted: Tue Sep 04, 2012 8:36 pm
Unfortunately not. It's the Mr Gasket one.
http://www.oreillyauto.com/site/c/detai ... +universal
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Tue Sep 04, 2012 8:56 pm
Pictures 2 & 3 look like the type I'm thinking of.
The body is just round rather than square......
If you can blow thru it with your mouth, it can be at the tank side and off without affecting the mechanical pump.
PostPosted: Tue Sep 04, 2012 9:53 pm
…speaking of Chinese fuel pumps… :-(
PostPosted: Tue Sep 04, 2012 10:44 pm
sigh
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Sat Sep 08, 2012 10:42 pm
done!
primed the carb, set the choke, turned the key and she fired right up!
I got a mexcan made fuel pump from o'rielly, after inspecting and rejecting a korean made one from Napa. napa's pump was defective right out of the box.
the fuel line mod went well too. after reading the posts regarding this mod, i was afraid i'd have a difficult time sourcing the correct fittings, but they were easy to find at both my local napa and o'reilly stores.
thanks slant6 forum.
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
PostPosted: Sat Sep 08, 2012 10:45 pm
I have no objection to Mexican- or Korean-made auto parts on general principle, though as with parts from anywhere they must be assessed on their merits. What was the matter with the Korean pump?
(I do have an objection to O'Really? Auto Parts? because, like Autozone and Pep Boys and Checker and Schuck's and Kragen, most everything they sell is garbage.)
Yayy!
PostPosted: Sat Sep 08, 2012 11:39 pm
when i actuated the lever there was absolutely no suction at the intake tube.
yeah, you're right. and i can't say that Napa is all that much better. for my "newer" truck, i always prefer to get actual motorcraft parts, but that usually means a trip to the dealer. but what to do for our older cars? ebay for NOS stuff?
Yayy!
That's what I said
1966 Dart Wagon
1967 Volvo 122s
1989 Ford F350 4x4
Users browsing this forum: Ahrefs [Bot] and 4 guests
