It is currently Sun Jun 14, 2026 3:50 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Wed Jun 03, 2009 7:12 pm
Even on stock intake? Like the carbed 2.2 intake? The plenum size in these is also large. About 1/2L to roughly 3/4 of a liter. I get sag at light tip in, but if I get flow going, well like the amount of throttle that would make engine gag like at small tip in is sufficient for cruising speed.
Cheers, Wizard
PostPosted: Thu Jun 04, 2009 8:24 am
Doc, did you use your holley or that E-brick to do your passes?
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Thu Jun 04, 2009 2:01 pm
I used the same 750 "E-brick" that I was running on the other manifold.
Yes... If I step down on the CFM the off-idle responce is likely to pick-up a bit.
Like I said... I bet I can get this unit to work better by spending some time (and $$) on it but that will have to wait for another day.
Along with the need for linkage mounting points, the Auzzyspeed people should think about extending the runners up into the plenum a little more, that would help make the manifold more off-idle and mid range responsive.
PostPosted: Thu Jun 04, 2009 5:12 pm
Poser
So Doc, I will ask THE stupid question. What if a guy were to divide the plenum on the hurricane and reposition the carb, primaries toward valve cover......
PostPosted: Fri Jun 05, 2009 11:36 am
Dividing the plenum and turning the carb "sideways" is what I would do next... if I owned this manifold.
That is what I did to the reproduced H-pak manifold to get it working better with a full throttle "hit" from idle.
PostPosted: Mon Jun 08, 2009 10:04 pm
I thrashed on the race car all last week and switched back to my divided plenum H-pak, then we went racing at Sanoma. (Infinion race)
The car is back to taking a full throttle "hit" and leaving hard.
I made 5 passes, the first one was a 13.17 with some high RPM "popping", that went away after changing to a clean set of spark plugs.
The best time for the weekend was a 12.70 at 104.5 mph, with a 1.79 60 ft time. The car feels the same as before the intake swaps.
So now I look for some better ETs in different places...
It never really ends when it comes to running a fast racecar.
PostPosted: Tue Jun 09, 2009 4:33 am
Poser
Doc could you give us your overall opinion of this intake. Cost. Street? Strip? This intake as compared to Offy/Clifford offerings? You know a consumer's report type of thing. :D This might be helpful to guys that may be thinking of joining in on Lou's future group buy. Thanks, Wayne.
PostPosted: Tue Jun 09, 2009 5:00 pm
Over-all, the Hurricane is a nice SL6 4 bbl performance intake.
As I have shown with my testing, it is not the best choice for dragstrip work but it would work well for all other uses where you do not need to go from full closed to full open throttle... instantly. (drag racing)
This intake does not have manifold heat so cold weather operation is going to be hard.
The manifold does not have a linkage kit and it's lenght does not lend itself to easy installation of automatic trans kickdown linkage. This is not a concern for manual trans cars but you need to be able to fabricate some linkage brackits... no matter what you use the manifold on.
PostPosted: Thu Jan 10, 2013 9:33 am
Are the Hyper pack runners larger than the Hurricane?
Mopar or no Car!
PostPosted: Thu Jan 10, 2013 9:56 am
Factory H-pak runners are not larger then Hurricane runners.
Dutra "Fat-pak" manifold runners are larger.
PostPosted: Thu Jan 10, 2013 12:13 pm
Thank! :wink: Id like to get a dual barrel hurricane for my 225.
Mopar or no Car!
Users browsing this forum: Bing [Bot], mraley and 9 guests
