It is currently Thu Jan 01, 2026 8:13 pm
PostPosted: Tue Jan 08, 2013 7:16 am
What is the correct ballpark exhaust temp. On the #6 runner. I have a huge difference in temps.
1- 318*
2- 350*
3- 361*
4- 359*
5- 355*
6- 242*
Pretty sure this is not normal. I do have issues keeping the car idling in gear that started recently. Thinking this is causing the problem. I'm going to check the plug condition and runner for a possible vacuum leak this afternoon. Any feed back is appreciated.
74 Dart Swinger, supersixed.
PostPosted: Tue Jan 08, 2013 8:46 am
WAG is it is ingnition related. But maybe some one that really tunes em to the nth degree will chime in and have an idea...
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Tue Jan 08, 2013 6:24 pm
Is the pipe plug in the #6 runner
or
is there a vacuum hose connected to it?
PostPosted: Tue Jan 08, 2013 6:51 pm
Vacuum, is going to the brake booster. No plug.
I got in late tonight so I was not able to look at anything. Will try again tomorrow.
 Post subject: .
PostPosted: Tue Jan 08, 2013 6:55 pm
emsvitil is close on this one, check for a leaky brake booster,or vacuum lines
PostPosted: Tue Jan 08, 2013 7:28 pm
What does the #6 runner usually run at as far as temp? Should it be consistent with the others..
I will try plugging the booster and retaking temp readings tomorrow.
PostPosted: Sat Jan 12, 2013 3:25 pm
Well I found no vacuum leaks, changed the plugs with nkg's checked compression (160) ignition to all cylinders were good. I went ahead and relashed the valves a little lighter to .013 and .018. This smoothed out the Idel. they were at .012 and .015 (it is a comp cam spec recommend .010 and . 012 but we all know that's to tight)
The temp is still low on #6 exhaust runner.... Any ideals. Cars runs good.. Should I be worried about the low temp? Can anyone give me some feedback on what there's reads. A few pics on the link below.
http://s1270.beta.photobucket.com/user/ ... %20rebuild[/url]
PostPosted: Sat Jan 12, 2013 3:33 pm
Corrected link. I think...
http://s1270.beta.photobucket.com/user/ ... mail_share
PostPosted: Sat Jan 12, 2013 4:23 pm
It all sounds cold for exhaust.
Check valve lash.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
