It is currently Mon Apr 27, 2026 7:51 pm
PostPosted: Fri Feb 01, 2013 2:34 pm
This is the only ATF+4 I can find in town (Walmart).
Is one brand better than another?
Should I wait until I go into the Big City and buy some other brand? :lol:
1964 Dart GT
 Post subject: .
PostPosted: Fri Feb 01, 2013 3:49 pm
I recomend Dexron II/III or ford type "F" for older non lock-up transmissions. I'm not very fond of ATF+ fluids for older high mileage trans. The high detergents can loosen sediment collecting in the valve body.
 Post subject: Re: .
PostPosted: Fri Feb 01, 2013 3:55 pm
Isn't that a good thing? Then the filter and magnet catch the loosened sediments and all is well.
PostPosted: Fri Feb 01, 2013 5:16 pm
Rebuilt engine and (soon to be) transmission, and I ain't fancy enough to have a magnet(or a drain plug for that matter!) :shock:
1964 Dart GT
 Post subject: Yeah but...
PostPosted: Fri Feb 01, 2013 6:06 pm
Much like cleaning out an old engine it might loosen something that won't get caught by the filter or the magnet, and or loosen something that was helping seal a slow leak causing another issue...then he has issue creep with the tranny, when he could have just topped up and drove until it really needed an over haul...
Oddly, E-berg in his articles uses Super tech oil and tranny fluid (Type F) usually... for tranny tweaks and the other stuff for new overhauled trannies.
Oh wait a minnute...forget the tranny fluid, just replace the whole thing with a 4 speed and clutch...no fluid change needed! :lol:
Yeah,Right!!! :wink:
PostPosted: Fri Feb 01, 2013 6:35 pm
Well, there is that....
PostPosted: Fri Feb 01, 2013 6:39 pm
Don't think that hasn't crossed my mind!
1964 Dart GT
 Post subject: '
PostPosted: Sat Feb 02, 2013 12:58 pm
I was reffering to sediment that's fine enough to pass through the filter,but settle in the valve body,like this:
This VB came from Rick covalt's blue car. It was working fine,but he removed it so I could perform my own shift kit mods.
PostPosted: Sat Feb 02, 2013 1:41 pm
I see that same sediment in every trans I have ever opened up, regardless of make, model, or fluid being used.
PostPosted: Sun Feb 03, 2013 8:15 am
Me too, I just squint a little and it goes away :D
As far as the ATF+4 goes, I don't worry about brand, I actually believe any brand sold as such* needs to meet a stringent spec and in this case, that's good enough for me. (*I mean those labelled as ATF+4, not the "fits all cars" type that says "meets or exceeds " in the fine print.)
EDIT: I have yet to read it all but ATF+4 info and license list are here:
http://www.centerforqa.com/licensingprogram.html
http://www.centerforqa.com/licensedatf4brands.html
Super Tech is on the list.
1966 Coronet Deluxe
