It is currently Fri May 15, 2026 10:12 am
 Post subject: tune up
PostPosted: Tue Mar 12, 2013 8:40 am
Looking for someone in St Louis area to tune up a super 6 in a 79 aspen. I am going to pull engine and trans to put in my rat rod. Want to get engine tuned while in the aspen. I am located 30 miles east of Stl.
Slant 6 Low Life Limo
PostPosted: Tue Mar 12, 2013 9:28 am
I don't live locally but a tune up is pretty easy and straight forward.
Depending on how far you want to go but a basic tuneup is replace plugs, wires and fuel filter. Clean cap and rotor. Oil change and filter replacement. Air filter cleaned or replaced. You could also rebuild your carburetor.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Tue Mar 12, 2013 12:38 pm
I am thinking I may want to get elec ign and possibly change cam. The Rat Rod is pretty wild, so I thought I would have a good sounding /6. I def have all of the power I need for now.
 Post subject: If...
PostPosted: Tue Mar 12, 2013 4:47 pm
If the engine is a real super six the EI distributor is a good one for 'sporty' modifications having the short governor for lots of initial... so make sure you keep that part of your ignition system.
PostPosted: Wed Mar 13, 2013 7:45 am
Engine is def super 6. I am pulling engine from 79 asspen, I want to do any mods while engine is in car so i can drive it before putting in rat rod.
I appreciate all of the forum input and info. Needless to say I am not a engine tuner, however I am a good driver.
 Post subject: I would...
PostPosted: Wed Mar 13, 2013 8:15 am
FYI, the 1979 is a heavy car so you will redial the carb and timing if put in a lighter chassis to get the most out of the engine. When the engine is out of the car I would replace the timing set to make sure it's all tight and good, and degree the cam to make sure the previous owner/mechanic didn't just line up the dots and retard things...
Sounds like a good project.
PostPosted: Thu Mar 14, 2013 7:52 pm
Mr d.idiot
I always appreciate your input with the forum. Will do as per your advise and others. The /6 forum is tops, will keep everyone informed as to how the rat performs.
tks
Users browsing this forum: Bing [Bot], Google [Bot] and 35 guests
