It is currently Sun Oct 11, 2026 1:19 am
PostPosted: Sun Mar 17, 2013 8:48 am
For u pro's where is the best place on ea. Side of motor to raise motor in and out of vehicle? Thanks Dana
PostPosted: Sun Mar 17, 2013 9:19 am
With the head still in the car there is are 2 half inch bolt holes that you can attach to with either a leveler or a length of chain. Without that I would recommend a bolt in each corner of the head bolt locations meeting in the middle to lift from.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon Mar 18, 2013 5:34 am
between the valvecover and manifold are 3/8 sae course thread holes, might have to remove some brackets to use
PostPosted: Mon Mar 18, 2013 12:57 pm
Use a single bolt and a "looped" strap, bolted onto the front bolt boss only, when pulling / installing the engine only.
Run a strap between the front and back bolt bosses, when pulling / installing the engine with the transmission attached.
Users browsing this forum: Google [Bot] and 8 guests
