It is currently Sat Nov 14, 2026 7:14 am
 Post subject: 3-on the tree tranny's
PostPosted: Wed Nov 26, 2003 5:22 am
In the61-62 valiant/lancer's with 3/tree shifting- is the tranny the same as a floor shift model or are they different? Have a friend trying to fix the family heirloom 61 Lancer & is having problems. I know some one out there should know .Thanks
PostPosted: Wed Nov 26, 2003 6:13 pm
the trans is the same but the word is that the bellhousing for the floor shift model is different, that bell housing slants the trans to the driver's side to allow clearance for the floor shifter and linkage.
PostPosted: Sun Nov 30, 2003 9:43 am
this is a good topic...
My 69 dart has a 904 trans I believe and I'd sure like to get a three on the tree in there... Any ideas on what would make a good donor car for bolt-in installation? A list of parts I should get? Don't want to miss anything.
PostPosted: Sun Nov 30, 2003 1:41 pm
The linkage tends to wear out and you'll have a lot of groaner skipped shifts. Go three or four on the floor, you can get donor parts out of any 1968-1976 A-body, and trannies and bellhousings out of any 1968-1979 A/F bodies depending on your preference for OD or not OD...
Go to the article section for 4 speeds, it'll give you some ideas.
PostPosted: Sun Dec 21, 2003 9:07 am
Ive now thought long and hard over this, and I'm deadset against cutting a hole in my floor for a floor shifter, simple as that. Plus I owned a Blazer tree shift truck once, and it was a ball. It doesn't look like I can get an auto trans with the gear spread I want unless I do some hacking either. So for the moment this makes the most sense in that an extra pedal is the only big appearance change. Does anyone know the problematic wear points in these columns? I can't imagine this can't be overcome with regular lubrication, a harder bearing material, or some hard face welding on the steel parts... Hmm, maybe with some creative fabricating I could throw an 833OD in and make it work?
 Post subject: lubricate? yea right! :)
PostPosted: Mon Dec 22, 2003 3:48 pm
Regular lubrication?? Hee hee ho ho ha ha ha ha! Don't do that to me, you'll make my insides hurt. :D Have you ever seen anyone disassemble a steering column to clean and lubricate shifter linkage?
I laugh because I've actually considered it. 8) Especially on a relatively low-mileage specimen that still feels solid, it seems like it's about time I attempted that job. After all, 40 years is long enough for it to go humming along merrily. Whenever I get around to separating the drivetrain and glass from the body to do the paint job, I'll see what's inside the steering column. In the meantime, a few shots of silicone spray lubricant on the exposed linkage have done wonders.
Sure, as long as you never need to back up the car. ;)
- Erik
PostPosted: Mon Dec 22, 2003 4:04 pm
man... I really need to get a look at a column. I know virtually zero about manual shift linkages. I do know enough that the lever doesnt actually follow channels cut for it in the base, but is limited by the fork levers in its travel. I was thinking narrowing the throws together and adding a third throw for OD, but translating that to the column? Im sure theres a reason they never used the tree for a fourth gear... I also can't get over how out of place a floor shifter would look in my four door, especially since I am so gentle on the controls I can't see myself wearing it out unless it's a defective design.
PostPosted: Thu Dec 25, 2003 4:49 pm
There have been several foreign cars that came with 4 on the tree and a reverse. My father owned a Renault 16 (I think it was) that was equipped that way.
PostPosted: Sun Dec 28, 2003 6:12 pm
Heh... don't give me any ideas :twisted:
PostPosted: Mon Dec 29, 2003 9:21 pm
Abuddy of mine put a a833 in a a-100 van and used the column shifter for the forward gears and put an extra stick in the floor for reverse,this required that the column shifter be put in nuetral when using reverse but it worked fairly well.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Tue Dec 30, 2003 6:06 pm
Heh... wouldnt help me keep my floor in one piece... Maybe I could run a cable to the appropriate fork and use a pull handle under the dash for reverse. Heavy cables are pretty commonplace on trucks and heavy equipment...
