It is currently Thu Jun 18, 2026 8:20 am
PostPosted: Sat Mar 30, 2013 6:50 pm
how was the distributor curve set up on the feather dusters im trying to get the best fuel economy i can out of my valiant
trying to keep it low key here in my Valiant200
 Post subject: Lots of timing...
PostPosted: Sat Mar 30, 2013 7:48 pm
These were designed with lots of timing, and an EGR to knock it all back to barely run well (stock this car could no get out of it's own way...but highway cruise very nicely). Also the Holley 1945 is a vehicle only peice calibrated to work with these parts. To give an approximate to the vacc advance on an EI distributor step up to a Standard motor products VC-208 make sure the adjustment is 3 turns out from tight for close proximity to factory settings. You may get ping as it's going to give you 22 degrees of vacc. advance almost all the time...
PostPosted: Sun Mar 31, 2013 7:40 am
my engine is a stock 1969 225 slant with a 1971 slant cam and the valve lash set at .012 intake and .024 exhaust with a holley 1920 with a 55 jet to top it off im going to change the jet to a 58 or 59 when i convert it to electronic ignition
PostPosted: Sun Mar 31, 2013 11:03 am
I am running the VC-208 can (22 degrees of vacuum advance) , with 20 degrees mechanical and 10 degrees initial. It is a close as I can get to the Feather Duster timing (52 degrees). Instead of running the EGR, to soften the timing I run alcohol and water injection which kicks in at 2000 rpm. That keeps it from pinging on a hot day and keeps engine head clean.
Users browsing this forum: Bing [Bot] and 5 guests
