It is currently Thu Jun 18, 2026 6:29 am
PostPosted: Sun Apr 28, 2013 6:31 pm
Mocking up t5 .. I have a od4spd bell housing its too deep for the t5 and a spacer would be worse .. is the aluminum 3spd housing shorter in length form engine surface to tranny face ???? ThNks
1963 Plymouth Valiant Wagon
PostPosted: Sun Apr 28, 2013 6:56 pm
Nope. Input shaft lengths are the same so the bell depth is the same.
 Post subject: Too bad...
PostPosted: Sun Apr 28, 2013 7:11 pm
If you had a 1968-1987 crankshaft installed you can install a dakota pilot bearing as the bearing sits in the crank pocket not the crankshaft itself...this would buy back about 1/2-3/4" of input shaft length to support it.
Your sig shows a 1963, so that is TSOL unless you can have one machined up special for your application.
