It is currently Sat Apr 25, 2026 6:45 am
PostPosted: Sat Apr 27, 2013 5:26 pm
ok so i have a 71 slant 6 with 55-60k miles on it just bought it from the second owner. it had an exhaust leak from the manifold. i decided to upgrade to a 2bbl so i installed a new exhaust manifold , 2bbl intake, kick down etc. I am having trouble finding how to fit the supersix air cleaner on so in the meantime i wanted to get it moving so i put a cheap air cleaner on and the breather and pcv arent hooked up yet. Ok so the brand new problem : i drove 70 miles and went through 4 quarts of oil. i just changed with penzoil 10w40 and 32 oz lucas. I was not burnig oil before the conversion. any ideas? maybe its obvious? help please thank you
I had a dream that I got my 1970 challenger back- and I vow to restore it and never again sell it for any reason- then I wake up with my stomach it knots realizing its gone ...
PostPosted: Sat Apr 27, 2013 5:55 pm
6 Pack Dart
I think you might have created this problem,
If you get these hocked up you might find the problem. :)
Richard
PostPosted: Sun Apr 28, 2013 9:49 am
Why the lucas?
PostPosted: Sun Apr 28, 2013 5:52 pm
Why the lucas?
It's magical snake oil! :)
I wonder if the float is set right on the new carb.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Mon Apr 29, 2013 10:30 am
Better get these hooked up to equalize the pressure in the crank case or it will keep loosing oil.......I did that once and had a similar experience. Pretty surprising.....especially on a new motor!
What is wrong with your air cleaner? I am running a super six air cleaner with a Holley 1920. Everything is hooked up too!
PostPosted: Mon Apr 29, 2013 11:31 am
Not possible without an adapter. The carb throat is a different diameter between the 1920 and the BBD or 2280. Stock Super Six air cleaners will only mount correctly without an adapter to Carter BBD or Holley 2280 Carburetors (or some Strombergs, but you never see those).
The Super Six air cleaner is designed to mount on the carb with the snorkel pointed towards the battery. Your 71 Dart may have had the snorkel pointed to the other side of the engine compartment. The Super Six air cleaner will not sit properly on the carb unless the snorkel is oriented properly.
PostPosted: Wed May 01, 2013 3:10 pm
Just use a base off a truck 1980 up Holley 1945 air cleaner with the smaller diameter base. It and the Super Six set up are the same using the cold air intake and hot manifold air but with different base diameters. I rotated mine a little more to the front for the cold ram air intake.
No adapter required.
PostPosted: Thu May 02, 2013 11:40 am
ok i was my error i had the vent from the fuel pump on vacuum and it sucked the oil from the crankcase everytime i put a load on it- the pcv was supposed to go there- thats what i get when i try and work with my daughter around Still have the air cleaner problem i have ac and the rear suction hose with the muffler is too much to fit the super six air cleaner
PostPosted: Fri May 03, 2013 10:15 pm
Sounds like a job for Mr. BFH! :shock: :shock:
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
