It is currently Sat May 16, 2026 2:05 pm
PostPosted: Tue Apr 30, 2013 3:46 pm
I'm busily micing my crank for my 225 rebuild. Picked up a set of Harbor Freight (I know..) micrometers. They only measure down to .001", but was hoping they'd work.
Here's photos of my readouts. Even if I'm not reading to the .0001" there seems to be something wrong because I'm reading that I'm OVER spec on my readouts. FSM states main bearings spec is 2.7495-2.7505. Don't understand how that could be, unless I'm totally reading the micrometer wrong. I made sure to calibrate the micrometer to 0, then to get the anchor and spindle positioned correctly on the main journals, taking into account I probably didn't want to measure in the middle because there's the oil groove there, so possibly less wear, so I offset the pins from the journal center to get an accurate wear reading.
Here's the photos, what do you all think? With the exception of MB #4, they all seem to be around the same readout, which makes me think I'm reading the mic wrong....:
General Setup
Micrometer I'm using
MAIN 1 HORIZONTAL READOUT
MAIN 1 VERTICAL READOUT
MAIN 2 HORIZONTAL READOUT
MAIN 2 VERTICAL READOUT
MAIN 3 HORIZONTAL READOUT
MAIN 3 VERTICAL READOUT
MAIN 4 HORIZONTAL READOUT
MAIN 4 VERTICAL READOUT
PostPosted: Tue Apr 30, 2013 4:33 pm
6 Pack Dart
I read that as 2.751"
Richard
PostPosted: Tue Apr 30, 2013 6:40 pm
Same, 2.751.
And don't look past the HB tools. Part of my job skill I learned at Ft Lee is micrometers and torque wrenches. I checked my HB TQ wrench and was well within limits.
There's also a magazine that done a write up on them as well, turned out good in it also. They even used one of the digital extension style and worked great.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Tue Apr 30, 2013 6:41 pm
All but the last one are around 2.7495 which I see as 2.7513
PostPosted: Tue Apr 30, 2013 6:43 pm
Lock it at 2.7505 and use it as a 'go/no go' gauge
PostPosted: Tue Apr 30, 2013 6:52 pm
Calibrate the 0-1" to 0
Then measure the 1" calibration with the 0-1" mic
If it's 1", calibrate the 1-2" with the 1" calibrator
If it's not 1" calibrate the 1-2" to whatever the 1" calibrator actually is (i.e .999 1.0001 whatever)
Now you have the 0-1 and 1-2 calibrated.
Measure the 2" calibrator with the 1-2 mic and do the above to get the 2-3" mic calibrated...........
PostPosted: Tue Apr 30, 2013 7:19 pm
6 Pack Dart
Good sound advice !!
Richard
PostPosted: Tue Apr 30, 2013 7:21 pm
Thanks. So I guess I need to work on learning to read my micrometers. Glad to know the mains all still in spec: figured, but couldn't quite tell. Got to do the same thing on the cam. The connecting rod journals I'm probably going to have to have ground because #6 spun. But I'll still going to measure it to be sure.
I wonder how I read it wrong.... Watched a few tutorials online about how to read these, but kept coming up with the same measurements....
PostPosted: Tue Apr 30, 2013 7:29 pm
That's how I'm seeing it too.
Richard
Agreed, great advice!
1966 Coronet Deluxe
PostPosted: Tue Apr 30, 2013 7:35 pm
6 Pack Dart
Having the whole crank turned is the best insurance for the money, juat be sure to run something like a gun cleaning rod with a patch on it through the oil pasages after it's ground same with the block if you have any work done on it or just for general principles.
Richard
 Post subject: Looks good...
PostPosted: Tue Apr 30, 2013 7:37 pm
That will be good practice, but if your machinist is hot tanking the block for cleanup before magnaflux and overboring, he will remove the cam bearings (they get chewed up by the hot tank) then toss them and install a new set (if you are ordering a kit he will just install those).
If everything is within spec you can go standard bearings on those. (I might be inclined to spend a few more moments shining the 'fat' journal with the 500 grit to see if it comes down a little more).
Mic the rod journals and see where they land, if the spun bearing journal isn't too badly scored/burned/ out of round, then you might be able to go .010 on them, if the machinist makes a mistake it might go .020...
PostPosted: Wed May 01, 2013 2:07 am
Also use the 0-1 to get the feel for repeatable measurements (i.e. 0 )
PostPosted: Wed May 01, 2013 10:05 am
Car Model: 64 Valiant
Also, when you take your crank to the machine shop, take your mic with you also and get them to check it against their mic and standard. Then let the machinist mic a crank they already have reground with your mic and then you mic the same crank and see how much difference there is between the reading you get and he gets with the same mic.
PostPosted: Wed May 01, 2013 9:01 pm
Thanks for the thoughts all. The guidance helped. Crank is mic'd. Now, on to the machine shop.
Users browsing this forum: Bing [Bot], Google [Bot] and 41 guests
