It is currently Fri May 15, 2026 2:52 am
PostPosted: Thu May 23, 2013 10:19 am
Car Model: 87 B150, 1970 Valiant 4-door
I never checked if the differential is centered.
The 2 closest junkyards that have LBP shafts for a 7-1/4" rear (per car-part.com). Each have only one, a peice.
Some junkyards note left and right.
These 2 yards didn't.
(I'm getting ready to bite bullet and convert to LBP to increase brake options. I was trying to hold out for a KH setup, but it's been almost a year and a half since I started looking...)
Is there any good reason not to just redrill the SBP axle flanges? (stock 225 w/A904, abolutely no performance mods planned ever, so I'm not worried about strength.) Is balancing a problem (again, never going to break 75 MPH, ever).
I'd have a machine shop do it, btw.
Please advise. Thank you.
 Post subject: .
PostPosted: Thu May 23, 2013 10:43 am
You must switch over the complete lbp rear assem. Lbp axles will not fit a sbp housing.
PostPosted: Thu May 23, 2013 11:27 am
Good to know. thanks.
That sounds like a good arguement for just redrilling the flange.
PostPosted: Thu May 23, 2013 11:31 am
just read on another thread that it can't be redrilled because of access hole to bearing retainer.
oh well.
What are the shortcomings to lbp front, sbp rear (other than that tire rotation gets pricey and time consuming).
 Post subject: 2x the fun
PostPosted: Thu May 23, 2013 11:53 am
You lose truck space because you have to carry 2 spares..
 Post subject: Re: 2x the fun
PostPosted: Thu May 23, 2013 12:39 pm
You can get dual pattern wheels!
just being a :twisted:
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Mon Jun 10, 2013 10:32 am
If it's not a race car putting down loads of power, I would vote for the billet aluminum bolt pattern adapters. You can get them 1" thick or maybe even narrower. You'll just have to check how much space you have in the wheel well.
That being said, there is a chance of adding some wheel imbalance due to losing your hub centering. You would now be centering on two separate sets of lugs per side. Might be a good excuse to try a very cheap and reportedly effective dynamic balancing system.
I would also avoid the cheaper cast aluminum adapters.
Escape Velocity Racing
PostPosted: Mon Jun 10, 2013 11:18 am
What a fantastic idea. I understand this concept entirely and will be trying it out this week for sure, I have a victim,,, ah, pair of tires ready to go.
Mattelderca
