It is currently Fri Jan 02, 2026 8:59 pm
 Post subject: Best port to read vacum
PostPosted: Wed Dec 17, 2003 11:07 pm
When setting timing and curb idle, which port on a non emissions Holley 1920 is the best port to read for vacum? While I'm at, how about on a Carter BBD as well?
Thanks
PostPosted: Wed Dec 17, 2003 11:36 pm
You want to read manifold (not ported) vaccum. I haven't ran a carb in a long time so I couldnt describe a specific port to you, but I can say that the line leading to the PCV is manifold vaccum so that would be a surefire ticket. If you have a power brake booster, the line going to that will work as well.
PostPosted: Thu Dec 18, 2003 4:26 pm
If your car doesn't have power brakes, there will be a pipe plug in the #6 intake runner that you can remove and put a spigot in its place. I just do this out of habit; the Toyota 4Y engine wouldn't run the same with the PCV valve unplugged and I couldnt get an accurate reading. Taking your reading in the plugged runner allows you to keep everything else intact.
PostPosted: Thu Dec 18, 2003 8:48 pm
You can use the vacuum port on the carburetor that your choke pull off line goes to.
PostPosted: Fri Dec 19, 2003 12:03 am
Thanks guys. I used the choke pull off port.
Thanks again
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
