It is currently Tue Dec 30, 2025 11:35 pm
 Post subject: D100 oil pump removal
PostPosted: Sun Jul 21, 2013 3:35 pm
UV dye showed oil pump site of oil leak, got oil pump off but there isn't room to pull it fully out of the engine even without the cover. Can I get it out without pulling the engine since that means a trip to a mechanic shop? I just need maybe 1 more inch room, its a 1985 Ram D100 225. Any advice appreciated, first time on forum, thanks
PostPosted: Sun Jul 21, 2013 3:38 pm
remove motor mount on that side. jack engine up from that side.
70 Plymouth Valiant 4dr
PostPosted: Sun Jul 21, 2013 4:40 pm
The exhaust may complain where it hooks up to the head pipe. Disconnect and drop the head pipe to keep from tearing the donut up, if so equipped.
Make sure you adequately support the engine once you've lifted it, or jacked it up. If it comes down, you can loose appendages. :shock:
Think safety whenever doing work of this sort. You should disconnect the battery too. Anytime your under the hood, it's good practice. :D
PostPosted: Sun Jul 21, 2013 6:14 pm
Thanks for the input, my main concern was what would not tolerate the onesided engine lifting and need disconnecting....radiator drain and hoses off? Too bad they left an inch too little space
PostPosted: Sun Jul 21, 2013 6:36 pm
Get a BFH and tap that fender in :twisted:
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 9 guests
