It is currently Tue Jun 09, 2026 12:14 pm
PostPosted: Sun Dec 21, 2003 2:19 pm
I've got the engine on a hoist and I'm trying to mount it to the stand. I can get all four brackets to mount up but I see a problem. The engine cg is above the pivot on the stand. The head is off BTW. If I want to flip it over the weight will be too much and I could have an accident. I have a 1200 pound hoist with four wheels BTW. Can I mount to just three points? The two lowest tranny mounts and one upper? Or should I go with four? I can see that when I remove the oil pan and crank I will want it upside down I think. Does this make sense? Advise please.
Thanks.
PostPosted: Sun Dec 21, 2003 4:16 pm
I always use 4 mounting points and center the pivot of the stand on the crank. Yes, you must be a bit careful and turn the engine slowly when it is on the stand. Slants are top heavy, even without the head.
PostPosted: Sun Dec 21, 2003 5:23 pm
If you were deadset on centering the CG at the pivot point youd have to fabricate new brackets or a new pivot head. I wouldn't bother unless you build these regularly. Just use a long bar on the pivot head and go slow.
PostPosted: Sun Dec 21, 2003 5:53 pm
Thanks, I'll do it now and give report. When you're dealing with several hundred pounds it gets my blood pressure up.
PostPosted: Sun Dec 21, 2003 6:24 pm
Toadie, is it a 4 point stand or a 3 point? 4 points are more secure, larger footprint.
PostPosted: Sun Dec 21, 2003 8:10 pm
Step,
It's a factory 4 point on the engine and a 4 wheeler. Anyway I got it on the stand. Crank is a little below center of pivot. I've got the pin in the pivot for now. I need to remove a few things and then I will flip it over tomorrow. I'll let you know how that goes.
Thanks all.
 Post subject: turning the slant over
PostPosted: Tue Dec 23, 2003 10:19 am
When in doubt, get a cherry picker over it and bolt a chain with some slack to the engine. Then, turn slowly. If you get into trouble, raise the picker and tighten the chain. I use this method when the engine is fully dressed. I also made sure to start witht he head straight up and let the engine down as far as possible where it bolts to the stand. The only thing better is a custom stand adapter mount like previously mentioned, but haven't seen the need for it.
Slant Six... out of the ordinary - just like me!
Users browsing this forum: Ahrefs [Bot] and 3 guests
