It is currently Mon Jun 22, 2026 3:08 pm
PostPosted: Wed Oct 30, 2013 6:10 pm
need the convert 1 bbl holley to accept rod style linkage. is best way to weld correct size washer (s) to carb lever? and drill out original hole to that size. i have no other ideas.
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
 Post subject: Which Holley?
PostPosted: Wed Oct 30, 2013 7:50 pm
Which Holley are you converting? (1920 or 1945?)
If it's a Holley 1920, the bracket for the rod linkage can be unscrewed and transferred. You might check to see if someone has a spare carb with a bracket they don't need before you do the welding.
(If it's a 1945, you will need to do the welding/fabrication).
PostPosted: Wed Oct 30, 2013 8:53 pm
Well, that's certainly one way, but one washer will allow the rod to move slightly, and wallow the hole larger and oval shaped. It may work well at first, but that wear will make the function less precise and you won't be able to get wide open throttle. Two washers spaced as far apart as possible would be better.
Best would be to find a rod operated carb & transplant the bracket, but I question welding or brazing on the throttle shaft. I think it might cause a vacuum leak. Maybe put the throttle body in cold water before heating the shaft??
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
