It is currently Fri Jan 02, 2026 6:14 am
 Post subject: Weber nomenclature?
PostPosted: Sun Jan 11, 2004 7:58 am
What does the DEGV, DGFV, DGAV and IDF mean regarding Weber carbs?
Thanks
PostPosted: Sun Jan 11, 2004 4:59 pm
ok here goes nothing i use to run these alot when i messed around with vws a long time ago
dc mean double throat
v mean verticle
o means horizontal
i means a downdraft
e means diecast
f mean ford or ferrari depending on where sold
v carb with a power valve
it seems that weber never used any rhyme or reason when it came to naming carbs and it was done in italian
ihave a chart that shows thew following for the letters you listed
dgav is a 2 vertical throat 2 shaft progressive carb
idf is a 2 vertical throat 1 shaft center float carb
hope that helps a little the other two may be newer carbs not shown on my chart
bp
pekingese parker all bark no bite and piddles on the carpet..... bad puppy
PostPosted: Sun Jan 11, 2004 7:31 pm
Thanks, that helps. It seems most people use the DGAV or the DGEV ( I had it wrong in my original post) for the slant six.
Thanks
PostPosted: Mon Jan 12, 2004 6:50 am
Here is what Chris from Proline told me.
"The DFEV is a modified carb, usually with some sore of Idle stop solenoid
for new cars and smaller motors.
A DGEV is a standard progressive with electric choke, DGV= manual choke, DGAV = Water choke-
DCNVH's are a newer style carb and are synchronis performance carbs- they are great carbs, but they do not carry adapters for them to bolt on
anything. All the set-ups using the DCNV's are custom machined intakes. x2 and x3 just means how many are in the kit."
Thanks Chris
Users browsing this forum: Google [Bot] and 7 guests
