It is currently Mon Oct 26, 2026 3:26 am
PostPosted: Sat Mar 01, 2014 4:48 am
striking out. looks like i might have to have one fabricated or just block off port. either way i will need a gasket. what type of material would be suitable to go against the franc case? the old gasket was completely gone.
tim@timforbus.com
PostPosted: Sat Mar 01, 2014 4:49 am
oh yeah. 77 volare. single barrel carb . all original parts/smog.
tim@timforbus.com
 Post subject: Charge Tube?
PostPosted: Sat Mar 01, 2014 8:27 am
Is this the smog tube that connects to the back of the head near the fire wall?
If so you can buy that gasket over the counter, or one of us may have a few left over from a full gasket kit. You can plate it off, or just use your old charge tube, cut it off about 2" from the flange, smack it flat with a hammer, and fold it over with some pliers about 2-3 times and install and it's sealed.
PostPosted: Sat Mar 01, 2014 10:31 am
so i know these were originally dome to help with emissions.... any downside to not having this valve and tube besides the extra emissions?
tim@timforbus.com
 Post subject: No.
PostPosted: Sat Mar 01, 2014 11:47 am
No, and unless your car is mint condition, it probably isn't working correctly anyway (the stock catalytic convertor isn't up to par either after 35 years of use). Does your area require smog tests on this car? If so, does it require a visual inspection?
If not, you can remove it with no impact
Users browsing this forum: DuckDuckGo [Bot], mr.norm and 8 guests
