It is currently Sun May 24, 2026 5:33 am
 Post subject: Machining question
PostPosted: Sat Mar 01, 2014 6:24 pm
I know this is a dumb question, I'm sure I already know the answer, just hoping I'm wrong lol
Can you have a slant head machined down without removing the valves and disassembling ?
joesnow AKA Dan
PostPosted: Sat Mar 01, 2014 11:44 pm
Yep ,just had it done two weeks ago . .085 off .
PostPosted: Sun Mar 02, 2014 3:38 am
I have had it done too. Make sure to clean it very thoroughly before installing.
PostPosted: Sun Mar 02, 2014 4:03 am
Not a stupid question, thanks for asking
PostPosted: Sun Mar 02, 2014 4:04 am
Online
You will need to remove the lower set of intake/exhaust manifold studs. If you don't, your machinest will be unhappy. His cutter will hit the studs if they are still in the head.
PostPosted: Sun Mar 02, 2014 4:33 pm
Great. Thanks guys. I like the answer, guess I need to go see my local machine shop...
joesnow AKA Dan
PostPosted: Mon Mar 03, 2014 5:39 pm
Just pulled the head off the slant that came in my '70 duster. Guy said some messed up installing a new timing chain. I'd say so. Five bent push rods...
joesnow AKA Dan
 Post subject: Push Rods
PostPosted: Mon Mar 03, 2014 7:09 pm
If you need some stock push rods let me know.
Rick
PostPosted: Mon Mar 03, 2014 7:15 pm
Ok cool... I probably will. Still deciding what I want to do. Waiting to get the car painted. Trying not to spend money until the paint is down lol.
Holding off machine work.
joesnow AKA Dan
PostPosted: Tue Mar 04, 2014 11:10 am
I have some stock push rods also. I also have a few extra pistons and rods. I am hesitant to get rid of them yet as I have another slant rebuild. Although I have not decided if I am just going to replace it yet.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Tue Mar 04, 2014 1:54 pm
Just pulled the head off the slant that came in my '70 duster. Guy said someone messed up installing a new timing chain. I'd say so. Five bent push rods...
You are well advised to dis-assemble this head and check for bent valves .
Valves can also get bent when they hit pistons hard enough to bend the pushrods.
PostPosted: Tue Mar 04, 2014 2:32 pm
Rokauto has pushrods for $1.50 apeice 27.29 with shipping
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Wed Mar 05, 2014 1:26 am
I'd finish the motor before it goes to paint. Don't want to drop that heavy head on new paint. :cry:
 Post subject: ditto
PostPosted: Fri Mar 07, 2014 7:06 pm
what Slantzilla said!
I did all the bodywork and paint on my Dart, then had to rebuild the head.
Even with special care, the paint still got nicked :evil:
PostPosted: Sun Mar 09, 2014 9:02 am
Motor is out... But yeah I don't want scratch new paint
joesnow AKA Dan
