It is currently Sat Jun 20, 2026 7:41 pm
PostPosted: Mon Mar 17, 2014 4:25 pm
I want to order a full gasket kit for my slant 6 as shown in the picture. I was told by the guy I bought it from that it is from a 1986 van. I have tried to verify this by the numbers on the motor without success. It is a newer style motor without the spark plug tubes like the 1970 one. The gasket kits are for 1980 and older and 1980 and newer. Am I safe to go with the 1980 and newer kit?
Attached are some pictures of the motor. Thanks for your help.
[/img]http://i1369.photobucket.com/albums/ag205/scraigallen/NewerMotor2_zps2412cece.jpg
 Post subject: Other Picture
PostPosted: Mon Mar 17, 2014 4:33 pm
[img]http://i1369.photobucket.com/albums/ag205/scraigallen/NewerMotor2_zps2412cece.jpg
Here's the other picture. Still learning how to attach pictures.
Thanks, Craig
 Post subject: That's telling...
PostPosted: Mon Mar 17, 2014 7:28 pm
If that early valve cover fits perfectly on the head, then it's a 1975-1980 BL head and you need the kit for 1960-1980... if the cover fails to work on one corner of the head because it has a detour in one corner of the gasket mating surface, then you need the 1981-1987 kit...
 Post subject: DusterI Reply
PostPosted: Tue Mar 18, 2014 5:40 am
The valve cover is the one that came on it and it seems to fit just fine. So based on the pictures, you think it is a 1975-1980?
Where would that detour be in the valve cover gasket relative to the driver and passenger side, and front and back?
Craig
PostPosted: Tue Mar 18, 2014 8:53 am
Lower front corner... (front, passenger side)
 Post subject: Thanks
PostPosted: Tue Mar 18, 2014 4:13 pm
Thanks for the input. I looked at my old 1970 motor and it is similar to the newer one. So I am 99% sure it is a 1975 to 1980 as discussed. I will pull the valve cover and head this weekend and check the casting number before I order the gaskets to make 100% sure.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
