It is currently Mon Oct 12, 2026 12:38 am
PostPosted: Sun Feb 01, 2004 9:13 pm
I got everything I need to convert my slant to electronic ignition, except directions.
there are 3 wires that i am not 100% sure where they go.
are there diagrams out there or can someone help me out?
also is the dist drive gear on the bottom supposed to be plastic? even the one on my air cooled VW is metal? makes me nervous fellas, put me at ease.
Caesar
PostPosted: Sun Feb 01, 2004 10:06 pm
Yep all the distro gears are plastic...
As for wiring diagrams, follow the articles link from www.slantsix.org
PostPosted: Sun Feb 01, 2004 10:09 pm
how well do the plastic gears hold up under high horsepower loads?
just curious.
caesar
PostPosted: Mon Feb 02, 2004 3:48 am
The load on the dist gear does not change with the horsepower level. It would rise slightly with rpm. I have never had a problem with a plastic gear, however I have replaced a small number of them on high milage daily drivers. If you are worried about it NAPA does have a steel gear, number DG-404.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 103 guests
