It is currently Mon May 11, 2026 9:41 am
 Post subject: Breathing
PostPosted: Wed Feb 04, 2004 8:13 pm
Would my engine run well with a 250 duration cam and a stock head with a two barrel carb? Or would I have to put a four barrel carb on there. I will be running 9:1 pistons bored thirty over. I would greatly appreciate the help because I want to get this engine on the road.
Scott Davisson
 Post subject: breathing hard?
PostPosted: Thu Feb 05, 2004 7:28 am
Your information is a little too vague. What is the lift on your cam and duration at 50?
PostPosted: Thu Feb 05, 2004 6:33 pm
I think it is a 252 or 254 duration and like 436 lift i think
Scott Davisson
PostPosted: Thu Feb 05, 2004 9:49 pm
Do you know who ground this cam?
It kinda sounds like the mild Crane profile.
If you have a local cam grinder you can get them to check it so you know exactly what you have and how it should be installed.
 Post subject: CompCam...
PostPosted: Thu Feb 05, 2004 10:32 pm
I'll bet it's the 252S comp cam since it's 252 with .435 lift...
If he goes that route, I'd suggest 4 barrel to get the most out of it, the super six tops out and goes flat in a certain rpm range....
Get back to us on the cam info, it's a bit vague...
PostPosted: Fri Feb 06, 2004 7:30 pm
yeah it is a 252S comp cam.
Scott Davisson
Users browsing this forum: Ahrefs [Bot], brummett and 4 guests
