It is currently Tue May 26, 2026 3:38 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Wed Oct 15, 2014 7:50 pm
Maybe the cam they sent him is a Mechanical cam?
I hope so, since everything else in the package is mechanical.
Also if you bought everything from Clifford, be aware that you do not want a high volume oil pump. As good as that may sound it is a recipe for disaster. A standard volume oil pump or even a used oil pump is what you want.
Sage advice here.
PostPosted: Wed Oct 15, 2014 7:54 pm
6 Pack Dart
The black would be the Nitriting (the hard surface put on new cams)
Richard
PostPosted: Wed Oct 15, 2014 11:19 pm
What it is and what they intend it to be may be different. This is from their site for part# 95-2021-K
6=8 Hydraulic Cam & Kit Our 264 Hyd cam ...... Kit includes: 264 Hyd Camshaft Hyd Lifters High Lift Springs Chrome Molly Retainers HD Valve Locks Heat Treated Pushrods (Cup & Ball for adjustable rocker arms)
 Post subject: Holy cow...
PostPosted: Fri Oct 17, 2014 7:50 pm
Man I feel bad for you....I have yet to spend over $1500 for rebuilding a slant with the cam and rebuild kit....and get plenty of power and mpg.
Sadly, Clifford in the past when Jack was alive was a good business, the reason they are still around is people don't research their build and buy the name only to get the lack of quality...
I seem to remember somewhere Doc had posted a thread here where a person had installed a similar kit that went to pieces at the show he was at, but was able to fix it with some handy mechanical valve train parts so the guy could keep motoring.
Make sure you get components that work together...note that cliffords 4 barrel intake was meant to work with their headers and will not bolt up to the stock exhaust manifold (if you want this feature you need an offenhauser intake).
The other thing that Clifford won't give you is a distributor recurve to fit your upgrade, and they aren't qualified to do it, so make sure you read up on the articles, there is lots of power and economy waiting when you match the timing to the engine build.
PostPosted: Sat Oct 18, 2014 1:35 pm
Alaskanmopar, you sound bound and determined to keep and use parts that you've been warned are probably not going to work well for you, from a vendor you've been warned is a notorious BS artist and scammer.
I'm just kinda curious to learn your line of thinking. You're wanting and hoping to do this engine build twice, first the wrong way and then the right way, or…???
:shrug:
PostPosted: Sun Oct 19, 2014 10:30 am
At least we'll have more carnage pics soon....
Dan, your prose is as sharp as ever.
PostPosted: Mon Oct 20, 2014 9:58 am
See page #2 for a story on another member who installed the Clifford kit of "mixed" hydraulic & mechanical cam / valve train parts...
http://slantsix.org/forum/viewtopic.php ... s&start=15
PostPosted: Mon Oct 20, 2014 11:51 am
Doc- that is an awesome story and I truly admire your track-side fix. 8)
PostPosted: Mon Oct 20, 2014 7:28 pm
Second that!!
Sam
