It is currently Thu May 28, 2026 4:37 pm
 Post subject: electronic ignition
PostPosted: Sun Feb 08, 2004 9:57 pm
Going to electronic ignition on my '66 slant. Still have mechanical voltage regulator, getting a replacement electronic unit. will this be sufficient for my application? (street driving)
Caesar
PostPosted: Mon Feb 09, 2004 4:56 am
I have this exact same set-up in my 66 Dart wagon, I have had 1 ECU failure in the past 12 years, that was with a used ECU. I replaced it with another used ECU. :roll:
Go ahead and do the conversion and remember, always carry a spare ECU.
PostPosted: Mon Feb 09, 2004 11:39 am
Are all ECU's same for all Mopar engines?.. .excluding Lean burn...
Mike C
http://cuda.iclownz.com
67 - Barracuda Coupe - 225 - Automatic
PostPosted: Mon Feb 09, 2004 5:03 pm
Where is the ECU located on an 87 pickup?
PostPosted: Tue Feb 10, 2004 8:05 am
Do a search on ebay for "slant six" and you'll find someone who sells NOS electronic distributors for $50- They usually come up every week or so.
72 Scamp 225 /6, auto, radio delete, alum super six, cold air duct, pertronix ignitor II and flame thrower, 3.23 rear, 2.25" free flow exhaust
PostPosted: Tue Feb 10, 2004 8:07 am
sorry, my previous post was meant for a different thread!
PostPosted: Tue Feb 10, 2004 10:16 am
according to haynes manual.it should be under the firewall feedthrough,drivers side.
there is only one...
PostPosted: Wed Feb 11, 2004 9:59 am
Steponme...
an '87 truck with a slant does not have an ECU unless someone has already converted it to 'standard' electronic ignition. The '87 should have a 'computer' on the drivers front fender behind the battery.
-S/6
PostPosted: Thu Feb 12, 2004 7:40 pm
Thank you!
So will the distributor on that truck be compatible with the standard electronic ignition box? What I want to do is use the parts off that truck on my Dart. Obviously I'm not interested in resurrecting the big ECU I saw right where you said it would be. :wink:
