It is currently Mon Dec 29, 2025 10:21 pm
 Post subject: Main bearings
PostPosted: Sun Mar 07, 2004 5:36 pm
I went to install the main bearings and crank today and found that the #3 bearing won't fit. The width of the main cap is 1 1/8" while the inside width of the bearing is only 7/8". The other three bearings (non thrust) fit fine. Could this bearing set be for a later cast crank block or something? Has anyone else run into this? Thanks.
PostPosted: Sun Mar 07, 2004 8:00 pm
I ran into this before, but not on a Slant. It was on an Iron Duke 2.5L 4cyl out of a Citation. Turns out I had selected a crank out of a pile of parts at high school that had a much larger crank journal diameter than my block allowed for. Weird.
My guess is your #3 bearing was packaged incorrectly. You can probably return it for the correct one.
PostPosted: Sun Mar 07, 2004 8:26 pm
Sounds like you have the cast crank thrust bearing.
You might want to check the other 3 bearings too, the narrow cast crank bearings may fit but are not as wide as the forged crank bearings.
PostPosted: Tue Mar 09, 2004 1:41 pm
They were indeed for the cast crank engine. They swapped me for the right ones this morning.
The kids and I will start bolting this thing together tonight.
PostPosted: Tue Mar 09, 2004 8:47 pm
Do you mean all 4 bearings were for the cast crank enigne as I suspected?
