It is currently Tue Dec 30, 2025 11:15 pm
PostPosted: Sun Mar 07, 2004 5:51 pm
I have a slant six with a 1 barrel aluminum intake manifold. I want to keep the manifold but install a 2 barrel for better gas mileage.
Does anyone know where I can find one at?
PostPosted: Sun Mar 07, 2004 5:54 pm
Chris at prolinefuel.com can help you out.
PostPosted: Sun Mar 07, 2004 5:57 pm
I don't want to run a Weber. That's the only problem with your suggestion.
PostPosted: Sun Mar 07, 2004 7:16 pm
I think Mr. Gasket makes an adapter. Don't know what kind of carb. you will have to use, though you can modify the adapters.
 Post subject: carb adapter
PostPosted: Sun Mar 07, 2004 11:37 pm
tried summit racing, they have a TD carb adapter #2025 for around $20
PostPosted: Mon Mar 08, 2004 9:40 am
The adaptor doesnt care what 2-bbl you put on it. I just used one of the Mr.Gasket that I got from Stovebolt.The 1-bbl opening may need some massaging to match the manifold. Also either shorter studs or carb spacer, as there is not much space as the adaptor flares in one position.
 Post subject: Becareful (Adapter)
PostPosted: Tue Mar 09, 2004 12:54 pm
Dude just make sure you will have enough hood clearance. i bought one and installed it the to find out . the hood would not shut. I have one brand new in the package if you need it. for some reason they sent me two..
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 4 guests
