It is currently Sat Jun 20, 2026 6:41 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Got It!!!
PostPosted: Wed Mar 10, 2004 5:02 pm
OK. I found 2 things wrong. The right rear directional/tail/brake light was jammed backward in the socket. Once that was corrected, everything but the left front directional worked. That turned out to be a dirty connection. Now all electrical functions properly. Tomorrow it goes to the tranny shop, then the alignment shop and then new door hinges so the driver door closes and then on the road....maybe a couple more weeks now.
Mike
PostPosted: Wed Mar 10, 2004 8:20 pm
The lighting should be independent of the horn circuit.
 Post subject: It Is
PostPosted: Thu Mar 11, 2004 6:24 am
I ran a ground direct from the battery to the horn. Haven't jacked it up yet but need to verify that still.
Users browsing this forum: Ahrefs [Bot] and 1 guest
