It is currently Mon Dec 29, 2025 9:36 am
 Post subject: Re: Volare 225 Project
PostPosted: Fri Mar 09, 2018 6:42 am
I got my harmonic balancer back yesterday from Damper Doctor, and it looks great!
I sent the pulley with it, not sure if that was necessary, but they repainted it and bolted it on with new bolts, in addition to rebuilding the balancer of course.
Getting closer...
'78 Volare 225
'67 Charger 318
PostPosted: Mon Mar 12, 2018 3:51 pm
Okay, so timing chain and sprockets. Is there anything that goes on under the sprockets?
'78 Volare 225
'67 Charger 318
PostPosted: Mon Mar 12, 2018 3:58 pm
Not under the sprockets, but you can add the oil slinger and don't forget the new crank snout seal in the timing cover.
PostPosted: Mon Mar 12, 2018 7:56 pm
Ok, so, is the oil slinger critical?
If it is, will an oil slinger from a 318 work?
Its been a while, not sure where the oil slinger from the slant is.
I do have a 318 with the timing cover off.
'78 Volare 225
'67 Charger 318
PostPosted: Mon Mar 12, 2018 10:45 pm
Oil slinger is not real critical. Many engines have gone together without one. A 318 one will work, and it does make life a little easier on the front seal.
PostPosted: Tue Mar 13, 2018 7:30 am
Ok, the oil slinger on the 318 is easier to get to at this time.
Thanks Dennis!
'78 Volare 225
'67 Charger 318
PostPosted: Tue Mar 13, 2018 9:52 pm
Ok, so I removed the harmonic balancer from a used slant in my garage, and the timing chain cover.
Lo and behold, there was no oil slinger.
So...
'78 Volare 225
'67 Charger 318
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
